Old 11-12-2000, 06:29 PM   #1
69Custom
69Custom's Avatar
Question Burning to lean
Hey all,
My 83 Daily driver is starting to get on my nerves. It is burning way to lean and have not really messed is electronic choke carbs. I dont have any spares of that kind laying around. What are my options?
Jerr
New Project
69 Chevy SWB, 67 front clip, 4 wheel disc brakes, 350 with 5 spd. (current project)
72 Blazer 4WD 307/3 spd, PS, PB, Posi (recent purchase)
83 Chevy SWB 350/200r4, buckets (daily driver)
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 11-12-2000, 07:26 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Post
The carbs on our trucks are not electronic. Everyone thinks they are because of the dual capacity pump. This is the wire that goes to the temp sensor in the thermostat housing.
You can swap on an older carb and it will work the same as it does on older trucks, as long as the linkage works. All the dual capacity pump does is when the engine is cold, it lets the pump double the capacity of fuel. When the engine reaches about a 160 degrees it closes the valve in the bottom of the carb and then acts just like a regular accelerator pump.
I have swapped out mine for an Edelbrock #1904 q-jet.
Hope this helps,
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Site
[This message has been edited by swervin ervin (edited 11-12-2000).]
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
