Old 03-12-2010, 08:11 PM   #1
jyukon
Smile side mount gas tank
I have a 66 Chevy fleetside shortbed that was converted to a 4x4. I want to move the fuel tank out of the cab but also want to keep the spare under the rear. Has anyone moved the tank under the bed in front of the rear axle between the frame and the driveshaft? I have read many threads about the rear mount tanks but haven't seen any about the side mount inside the frame. Is a custom tank the only way to go? I need to be able to stick with the 0-30 ohm sender also.
Thanks for your input.
jyukon is offline   Reply With Quote
Old 03-12-2010, 10:56 PM   #2
bubba327
HOW long until spring??
bubba327's Avatar
Re: side mount gas tank
I have spent many hours laying under my truck looking around for different options and location for fuel tanks. There are not many ways to get a tank around the drive line or near the trailing arms. Outside the frame is not a great idea for safety reasons,
So the only options I have really thought about is.... Back behind the seat, behind the rear axle, or in the bed hid in or under a crossbed tool box. Any other ideas , bring em on !
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 03-12-2010, 11:14 PM   #3
Slow Build
Slow Build's Avatar
Do you have trailing arms or leaf rear suspension?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-12-2010, 11:43 PM   #4
jyukon
I have leaf springs front and rear.
Old 03-13-2010, 09:06 AM   #5
lakeroadster
Here is a link to "The Stovebolt" where some interesting ideas have been tossed around:
http://www.stovebolt.com/ubbthreads/...730#Post623730
Since you have leaf springs one idea is to use a S-10 between the frame style tank like the one shown below.
http://www.autopartswarehouse.com/de...0106.html#desc
Hope this helps....
lakeroadster is offline   Reply With Quote
Old 03-13-2010, 09:35 AM   #6
jyukon
Thanks for the tip. I'm heading to the salvage yard today looking for S10s. Any further suggestions are welcome.
Old 03-13-2010, 10:07 AM   #7
lakeroadster
You've probably already done this but you will want to measure the depth - width - length you have under your truck for the tank and compare that with the S10 tanks overall dimensions.
These links have dimensions of S-10 Gas Tanks:
http://raybuck.com/i-66692-1985-95-s...ank-20gal.html
http://www.justgastanks.com/store/in...Path=67_84_294
http://monsterautoparts.com/CHEVROLE..._gas_tanks.htm
Looks like they are pretty long....
Crossmember interferences will likely be an issue...
If the tank is too deep it might look nasty hanging below the frame rail..
Good luck and let us know how it goes!
Old 05-12-2011, 06:46 PM   #8
aspiringthomas
aspiringthomas's Avatar
What if you leave the original trailing arms on a 1965 chevy C10. I am also look for ideas because I would like to move my tank out of the cab but also have an under mount spare tire. Thanks Jeff.
aspiringthomas is offline   Reply With Quote
Old 05-12-2011, 08:12 PM   #9
jbgroby
jbgroby's Avatar
I don't think this would work with the 60-63 X frame for GMC's, not enough room.
jbgroby is offline   Reply With Quote
Old 05-13-2011, 11:51 AM   #10
trevota
my 65 c20 has a side tank on both passenger and driver side of truck. they look like fuel cells??? not being used right now...............
trevota is offline   Reply With Quote
Old 05-13-2011, 01:12 PM   #11
mikie 1954
trevota, my 64 3/4 ton GMC has the same thing as yours. I think they were dealer installed and probably wound not work for him as his is a short wheel base truck. Mine hold about 20 gal each but maybe he could install two 10 gal ones?
mikie 1954 is offline   Reply With Quote
Old 05-13-2011, 01:26 PM   #12
creep
Registered Loser
creep's Avatar
63's didn't have X frames.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 05-13-2011, 05:25 PM   #13
gabe2000
here's my 5cents:
I went to the junk yard and got 2 different gas tank from s10 and none fits!!!
Only if u custom make one from a similiar shape of the s10. I even have pictures and it does not fit. The pics u see is from a S10 truck and 60-66.
gabe2000 is offline   Reply With Quote
Old 12-28-2016, 01:49 PM   #14
Dazzoman
Hey how about using an Ford Aerostar plastic gas tank and it should fit on the passenger side up near the cab inside frame so you can still have your spare tire area in tact plus the weight distribution would be optimal .
I haven't measured this but I own an Aerostar and had the tank out a few times . I will measure it up , if anyone is interested .
Of course going out on a limb is the Ford sender going to match the 66 Jimmy gauge ...?
Dazz man
Dazzoman is offline   Reply With Quote
Old 12-28-2016, 01:56 PM   #15
Dazzoman
[QUOTE=lakeroadster;3857796]Here is a link to "The Stovebolt" where some interesting ideas have been tossed around:
How about using an Ford Aerostar plastic gas tank and it should fit on the passenger side up near the cab inside frame so you can still have your spare tire area in tact plus the weight distribution would be optimal .
Dazz man
Old 12-28-2016, 02:15 PM   #16
oldies1938
my 66 c20 came with this side tank as well as the one behind the seat
oldies1938 is offline   Reply With Quote
Old 12-29-2016, 12:17 AM   #17
Dazzoman
Hey thats cool ! I wonder who makes that tank or where your previous owner got it ?
How many gallons ?
My 67 Dodge truck 1/2 ton had the filler like that and I had no problems w/ gassing up there ( like yours) near the tire .
Old 12-29-2016, 02:35 PM   #18
oldies1938
The truck has a gas door not sure if this was after market.
Old 12-30-2016, 01:18 AM   #19
Dazzoman
Saaweet !
How many gallons is that ?
Where can I get one ?
fuel cell, gas tank relocation, sending unit, spare tire mount
