03-13-2010, 11:53 PM | #1 |
Any thoughts on fuel tank?
first off I searched with no luck,,,,I am wanting to get the gas tank out of the cab on my 64..I was gonna just get the suburban tank kit,,but I'm poor/cheap,so I was also wondering about a fuel cell with sender,,for about half the price..I was told my factory sender may be 0-30 ohms and all the cells I can find are 0-90,,so is there any way to make this work?
03-14-2010, 08:20 AM | #2 |
Re: Any thoughts on fuel tank?
Brothers sells a universal fit 0-30 ohm sender. You will need to check with the fuel cell manufacturer though and make sure the sending unit can be replaced.
Sending Unit: Brothers P/N ATK59SU, 0-30 Ohm Universal, $29.99 http://www.brotherstrucks.com/prodin...number=ATK59SU |
03-14-2010, 08:55 AM | #3 |
It is kind of a pain but if you will look through this search you will find some info. http://67-72chevytrucks.com/vboard/s...archid=1572803
There is also some here. http://www.chevytalk.org/fusionbb/sh..._Chevy_Trucks/ look in the THE PIT STOP - Quick Reference Guide to Frequent Topics section for info about sending units. Hope it helps
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
03-14-2010, 09:21 AM | #4 |
I forgot to mention that I am thinking of using this 16 gallon tank.
http://www.summitracing.com/parts/JZP-200-016-NF/ I plan to use a sending unit like this. http://cgi.ebay.com/ebaymotors/ws/eB...d=330406022200 Summit has several that will fit. With and without sending units. you will need an aftermarket gauge with there senders. http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
03-14-2010, 01:48 PM | #5 |
"Where were you in '62?"
Here you go Bud:
More Pictures of the Fuel Cell Here: http://67-72chevytrucks.com/vboard/s...=321173&page=2 More Stuff Here: http://www.google.com/custom?hl=en&s...hevytrucks.com
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-14-2010, 02:01 PM | #6 |
Senior Enthusiast
Here's a few more links to look through on the subject:
http://67-72chevytrucks.com/vboard/s...light=gas+tank http://67-72chevytrucks.com/vboard/s...light=gas+tank http://67-72chevytrucks.com/vboard/s...light=gas+tank http://67-72chevytrucks.com/vboard/s...light=gas+tank |
03-14-2010, 02:23 PM | #7 | |
Where can you get a fuel cell w/sending unit for $100?
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-14-2010 at 02:26 PM. |
03-15-2010, 10:45 AM | #8 |
thanks for the help,,for some reason my search didnt turn up with those links..
03-15-2010, 10:49 AM | #9 | |
03-15-2010, 10:59 AM | #10 | |
03-15-2010, 08:36 PM | #11 | |
