Old 03-14-2010, 06:15 PM   #1
7ft stew
rear window stuck down.pics
im trying to figure out how to get the rear window up in my 76 blazer.im not sure what the box is thats attached.i think i have the crank but it doesnt seem to go in far enough.thanks for any info.stewName:  017.jpg
7ft stew is offline   Reply With Quote
Old 03-14-2010, 09:47 PM   #2
Teck
Teck's Avatar
Re: rear window stuck down.pics
The black box is the motor for the for the power window. The cable that screws in and goes to the regulator. You should be able to hook a drill to the cable to make it move. I think 78 was the first year for power window. Manual and power window ues different regulators that is why the manual crank will not work
http://www.lmctruck.com/icatalog/bzc/t.aspx?Page=24.
1986 K5 Blazer
Teck is offline   Reply With Quote
Old 03-15-2010, 12:19 AM   #3
7ft stew
So I should assume the tail gate is from an older blazer.wats the best way to fix it so I can roll the window up?thanks
Old 03-15-2010, 10:11 AM   #4
tobiahr
tobiahr's Avatar
No. The tailgate is from a 78 or newer. To get the rear window up you will need to spin the cable in the upper left of your first picture, the one that looks like a speedometer cable in blue. The electric motor will need power ran to it and you'll need to make sure the safety switch inside the tailgate on the drivers side is working properly as it keeps the motor from operating with the tailgate open. IMHO the best way to fix it would be to get a true manual tailgate. running wires from the front tapped into the fuseblock is always bad news.
tobiahr is offline   Reply With Quote
Old 03-15-2010, 06:45 PM   #5
Teck
Teck's Avatar
Look on page 25 at LMC link you need a manual regulator or go find one a the junk yard and the crank you have
1986 K5 Blazer
Old 03-15-2010, 10:21 PM   #6
7ft stew
awesome info guys.im just now starting to drive it and i get alot of exhaust fumes because its down.has anybody figured out what kind of exhaust to run and not get the fumes? I really dont think its possible.
Old 03-15-2010, 10:38 PM   #7
tobiahr
tobiahr's Avatar
it isn't. if the rear window is down it sucks the fumes in. i've had side before and after the rear wheels and directly out the back under the bumper and all sucked the fumes in with the window down
Old 03-15-2010, 10:38 PM   #8
Teck
Teck's Avatar
need convertors to help kill the exhaust fumes, then out the sides not the back.
1986 K5 Blazer
Old 03-16-2010, 10:25 PM   #9
USSkoval
Exhaust out the sides, just behind the rear tires. Little to no fumes unless you romp on it getting on the freeway or something. It REALLY helps to have the side windows rolled down too.
All bets are off it it's a worn out smoker
USSkoval is offline   Reply With Quote
Old 03-18-2010, 11:40 AM   #10
dropd80s
dropd80s's Avatar
Why do you say this? You mean not safe or not fun?
dropd80s is offline   Reply With Quote
Old 03-19-2010, 10:46 AM   #11
tobiahr
tobiahr's Avatar
both. the regulator in the rear window draws a lot of amperage and no one ever puts large enough wiring to carry that amperage across that distance.
