Old 11-21-2000, 01:23 PM   #1
bigd65
bigd65's Avatar
Post burb grill to a 85 C10
anyone ever do this swap was wondering what it all involves, i just got one at a wrecking yard for 100.00 buck wiring and all and now im fixin to install it
Jeff Dodson
85' C10-LWB 350/700R4
ANGLETON TX.
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 11-21-2000, 03:23 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Cool
bigd65,
The web site below gives details on converting '73 to '80 trucks to the '89 - '91 front end. A parts list is also listed for the '81 - to '87 trucks. http://www.coloradok5.com/grilleswap.shtml
Visit my web site for details on my truck's conversion to the quad side by side headlights style. If you have a 700R4 tranny, I would recommend installing a transmission oil cooler during the swap. I bought most of the parts from aftermarket suppliers.
Only things I bought from the dealer are:
hex screws, grill bow tie, (the little plastic squares that the screws screw into, headlight adjustments screw asseblies and adjustments springs. The springs are hard to find in parts stores. The headlights screws can be found at major part stores.
Good Luck,
gchemist
1983 Custom Truck
TX Plates: "BAD BOW"
http://www.geocities.com/abetterchemist/
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-22-2000, 12:45 PM   #3
bigd65
bigd65's Avatar
Post
i could swear i seen a post on this topic someone please reply. i thought i seen a post of somone getting all four headlights to work on high beams on this mod. thanx
Jeff Dodson
ANGLETON TX.
[This message has been edited by bigd65 (edited 11-22-2000).]
Old 11-22-2000, 07:22 PM   #4
JOE BOB
Post
JEFF, DID YOU CHECK OUT THAT SIGHT? THE PROCEDURE IS CONCISE, AND THERE ARE GREAT ELECTRICAL SCHEMATICS THAT SHOULD HELP YOU. ALSO, THANKS FOR THE POST, BECAUSE I AM HOOKED, THAT IS EXACTLY WHAT I AM GOING TO DO TO MY '85 BURB! LATER, JOE BOB.
JOE BOB is offline   Reply With Quote
Old 11-24-2000, 04:39 PM   #5
bigd65
bigd65's Avatar
Post
hey joe,
i did read the whole article it doesnt say anything about wiring it up. on the page that shows the wiring diagram it shows the green wire but only states not used and also has a loop around it and the tan wires and is marked "quad" what does this mean. if you hook them all together the it will not switch back to low beams. there has got to be a way to wire this to work. the original headlights were like that and all four stayed on on high's why wont this work with this grill sett up. if you are any good at figuring out wiring and you figure it out please let me know. thanx
Jeff Dodson
ANGLETON TX.
