11-18-2000, 06:51 PM | #1 |
Door locks.
I am having a problem.Sometimes if I lock my drivers side door by hand, I can't unlock it. Some times I can from the outside with key. Sometimes I can't. I have taken the door apart, and everything looks good. I have power locks. Any Ideas? Thanks.
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Crystal Lake IL. 30 Miles north of Chicago |
11-19-2000, 11:00 PM | #2 |
Hello.......(sounds of echos)
------------------ http://hometown.aol.com/racedvl/racedvl69index.html Crystal Lake IL. 30 Miles north of Chicago [This message has been edited by racedvl (edited 11-19-2000).] |
11-20-2000, 06:01 AM | #3 |
Hey Race, I've got an '86 GMC that I've put every one of the 191,000 miles on it, and it's done the same thing since the day it came off the car lot. Sometimes when you lock it inside, to get it unlocked, you have to roll down the window and push the button outside. Had it back to the dealer, and they replaced one side completely[although both sides did it] and didn't help at all. So, basically, I've lived with it. I'm interested if someone has a fix, also.
11-20-2000, 07:50 AM | #4 |
BAD BOW-Silverado XST
racedvl,
I've had the same problem. Seems like the locking mechanism and the button have a large clearance/space tolerance. I've had the passenger side not unlock when locked manualy or by the key. The problem went away when I switched the door lock switch. My guess I must have moved thing inside the door panel. Best way to get rid yourself of the problem is to lock/unlock the truck with the power lock button. Even better, like I just did, install a security system that uses the button locks with a "clicker". You can even just install a remote lock/unlock system for less than $70.00. My truck will now lock the doors when I turn it on and unlock when I turn it off. I can by pass this feature by having the door open then turning the key on. Security and no more door key!!! ------------------ gchemist 1983 Custom Truck TX Plates: "BAD BOW" http://www.geocities.com/abetterchemist/ |
11-21-2000, 08:52 AM | #5 |
mine 85 C10 did that and it was the electric door lock solinoid was old and was trying to freeze up. i replaced them with ones from a wrecking yard and it fixed except i got a bad plug on the passenger side, just to lazy to pull the door panel back off. hope this helps and good luck
------------------ Jeff Dodson 85' C10-LWB 350/700R4 ANGLETON TX.
2004 Silverado Crewcab (Dark Spiral Gray) |
11-21-2000, 08:48 PM | #6 |
Ya it don't allways unlock when you use the power locks. I like that soli. idea.
11-25-2000, 12:56 AM | #7 |
My 84 K5 Blazer does the same thing now and again. Mine unlocks easily when I pull the door towards me when its in the closed position. But won't open any other way w/power lock or the key. My dad had a 79 ton no power in the doors and the lock assembly completely locked up and could not open the door. Very unsafe situation IMO.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
