Old 04-10-2010, 10:15 PM   #1
HOGDADDY
HOGDADDY's Avatar
door mirror nuts inserts
Does anyone know where I can get the nut inserts for the Stainless steel mirrors on door-below eyeline large mirrors. thanks in advance.
I ended up using a nos door skin I had beacause 1 door had issues. and it has no provisions to mount the mirror. It should have 3 holes of which 2 are the nut inserts and one is just a hole.
So I just need 2 inserts.
HOGDADDY is offline   Reply With Quote
Old 04-10-2010, 10:28 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: door mirror nuts inserts
You can buy them from a supply company. They have various brand names such as Nutserts, Rivet-Nut, etc. You will need the tool as well. Be sure to put the reinforcement plate behind them or the skin will crack.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-10-2010, 10:47 PM   #3
HOGDADDY
HOGDADDY's Avatar
There was no reinforcement plate on the originals just the inserts. I found some called jacknuts
The only reinforcement I had to add was behind the door handle it had 4 tiny spotwelds 3 of em around the button hole and 1 on other end of piece. I may add some panel adhesive too (or an xtra spotweld) I dunno.
Btw I forgot about it til you mentioned the reinforcement thanks n2trux.
I can add it on even with the door skin in place by drilling a few small holes on outside of door panel and try be real easy on spotwelds with my mig.
Old 04-10-2010, 10:52 PM   #4
JR0187
Maybe its a dealer item. I didn't see anything like that on autozone. Have you asked your local parts store?
JR0187 is offline   Reply With Quote
Old 04-10-2010, 10:55 PM   #5
HOGDADDY
HOGDADDY's Avatar
No I may try NAPA tomorrow or if I can figure out the right size I may call these folks.
http://oemfasteningsystems.thomasnet...readed-inserts
Old 04-11-2010, 12:40 PM   #6
dswancutt
They are still available from GM. The part number is 367292, Group 16.0069. They are around $2.69 each
dswancutt is offline   Reply With Quote
Old 04-11-2010, 02:02 PM   #7
dswancutt
Did a little research on this and the true name is a Jack Nut. Here is a link for those who care.
http://www.prifast.co.uk/nutsert1.htm
Old 04-11-2010, 08:16 PM   #8
HOGDADDY
HOGDADDY's Avatar
I will order some first thing monday, thank you very much!
Old 04-11-2010, 10:13 PM   #9
Prong
Fastenal has them too.
Prong is offline   Reply With Quote
Old 04-12-2010, 08:14 PM   #10
HOGDADDY
HOGDADDY's Avatar
The local Chevy dealer had them in stock (said he had plenty) and I got couple xtra ones being they sold them individually (only few dollars) and they come with some pre-applied sealant on them.
I drilled 3 holes 3/8" diameter and had wallow 2 of them just a bit for the jack nuts to slip in, the 3rd bottom hole is just a hole as it has a metal bar/stud on inside of door.
I measured carefully and used the backing plate off an old mirror to make sure it was right.
Old 04-12-2010, 09:37 PM   #11
datguysaL
hey, if your talkn about the white plastic squared inserts, about a month ago i was helping my bro install his new mirrors and i ended up breakn 2 of them. we went to the auto parts and found them in the HELP section. its in a red box with HELP printed on it. that company sells alot of small parts like that.
datguysaL is offline   Reply With Quote
Old 04-12-2010, 09:52 PM   #12
HOGDADDY
HOGDADDY's Avatar
No not plastic these go on the door skin for the mirror it screws into these.
Genuine GM jack nuts with sealer applied already.
Old 04-12-2010, 09:56 PM   #13
datguysaL
oh, yeah i know what u mean,
my bros mirrors came with plastic ones. well hope u find them...
Old 04-12-2010, 10:05 PM   #14
HOGDADDY
HOGDADDY's Avatar
I did I picked these up at chevrolet dealer today
That is the actual pic of one I took with my camera.
Old 04-12-2010, 10:24 PM   #15
bigwheel15
bigwheel15's Avatar
On a slightly different note, how would one go about removing factory nut inserts? I'm changing from the dumbo ears to the smaller sport mirrors.
bigwheel15 is offline   Reply With Quote
Old 04-12-2010, 10:29 PM   #16
HOGDADDY
HOGDADDY's Avatar
I have actually been thinking of this very same question in my head. It sure is a pia to sand around these things and I was thinking of removing the ones on other door til its ready for paint or even afterwards.
I think you could drill straight thru it and then bend the ears back and push it back thru.
Old 04-12-2010, 10:46 PM   #17
bigwheel15
bigwheel15's Avatar
Thats actually what I was thinking of trying. That or just grind the head off it.
Old 04-15-2010, 01:31 PM   #18
HOGDADDY
HOGDADDY's Avatar
I got mine off by drilling with 3/8" drill bit and drilling slowly as not to make the insert spin or you will have try and hold it from backside.
On a side note there also is a special tool to install them and I think it keeps it from spinning too as it is tightened down on door. There looks like there are 2 different tools you can use to install them:
one is rather expensive and the other looks like it will install a few and it is cheaper I think.
Old 04-16-2010, 05:34 PM   #19
HOGDADDY
HOGDADDY's Avatar
I found a local place that is gonna order the cheap tool for me to install the Jack Nuts and I mean CHEAP like less than a $1.
Old 04-16-2010, 07:49 PM   #20
Oilbrnr
Oilbrnr's Avatar
So do those expand almost like a pop-rivet when the bolt is threaded in?
Not to hi-jack this thread too much, but what can be done when there is tearing around those holes, top one specifically on the larger tri-leg mirrors? Is there enough room to get a backing plate in there?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 04-16-2010, 09:14 PM   #21
HOGDADDY
HOGDADDY's Avatar
Well sort of. here it is in action. The tool expands it then you just screw fastener in.
http://www.emhart.com/products/pop/jacknut.asp
Old 04-16-2010, 09:57 PM   #22
HOGDADDY
HOGDADDY's Avatar
You could cut out a square piece around the hole, weld another square piece in its place and redrill the hole I suppose.
It may be hard to get a backing plate in there. I guess it could be attaced with panel adhesive cause it would be tuff to weld one there.
I am not a real bodyman (but I try) btw some may know a better way.
Old 11-17-2010, 08:30 PM   #23
HOGDADDY
HOGDADDY's Avatar
Here is some new info on jacknuts........Home Depot sells these and they already have sealer on them like the GM oem jacknuts.
Old 11-17-2010, 08:41 PM   #24
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Thanks for the information. I will be needing some shortly. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-18-2010, 03:07 PM   #25
jitteryguy
GoatLube Experss
jitteryguy's Avatar
you can take a nut and bolt and put thru a flat piece of metal, then start in the riv-nut, hold the metal and the bolt, then turn the nut down till it set's the riv-nut. we use all size's of them here but all the insert tools are long gone, so that what I do to install em.
the good insert'r has a bear'n on it like a power steer'n pulley puller, they work sweet, not worth the cost though unless your gonna instal a bunch of em.
I did the door's on my dually, I never thought bout reinforce'n behind it, Hope I dont have trouble later with em.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
