Old 04-10-2010, 11:34 PM   #1
bucannon
Salty Sailor
bucannon's Avatar
Talking What transmision should i get
hey everybody so i finially blew my transmision in my truck., it was a turbo 350. ive got smallblock. what transmissions could i possibly switch to.
i know i want an automatic and i want more gears. ive got a carb so what are my options on electronicly controlled transmissions?
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 04-10-2010, 11:38 PM   #2
60ratrod
yes, i do
60ratrod's Avatar
Re: What transmision should i get
700r4's are usually what get swapped in. now was the th350 a 6" tail or 9" tail? the reason i am asking is if its a 6" tail you may be looking into having a new drive shaft made. if you wanna go newer then a 4l60e is just the more updated computer controlled version of the 700r4. and the 4l80e is the electronic version of the th400
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 04-10-2010, 11:41 PM   #3
Captainfab
60-66 Nut
Cost wise you would be better off with a 700R4. If you were to go with either a 4L60E or the 4L80E transmissions, the aftermarket controler for those run around $1K
Old 04-11-2010, 11:11 AM   #4
bucannon
Salty Sailor
bucannon's Avatar
okay so it looks like the 700R4 is the way to go.
what vehicles had those. im pulling mine from a junkyard.
Savannah, Georgia
Old 04-11-2010, 11:28 AM   #5
bucannon
Salty Sailor
bucannon's Avatar
and oh yea ive got the 9" tail on the old th350
Savannah, Georgia
Old 04-11-2010, 01:05 PM   #6
60ratrod
yes, i do
60ratrod's Avatar
ok so you can get those outta camaros, firebirds, corvettes and trucks up to 92 i believe
Old 04-11-2010, 01:26 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Make sure you rebuild it... or you'll be doing this all over again... then again, sometimes you can get lucky with junkyard parts...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-11-2010, 03:24 PM   #8
60ratrod
yes, i do
60ratrod's Avatar
one thing you wanna make sure of though is the mileage. mileage can be a good indicator of condition. and i would drop the pan to do a filter and pan gasket. that way you can see if there are any major chunks and shavings in the bottom
Old 04-11-2010, 05:48 PM   #9
bucannon
Salty Sailor
bucannon's Avatar
okay yall after my junkyard run i found one in a dually c-30. it is hooked up to a big block, will it still bolt up to my smallblock?? and i plan on pulling the pan and cleaning out/checking up the tranny.
can yall tell me more about the 700R4 like what ratios it has and why it is it considered better
the V.I.N. for the dually is
1GCHC33W2ES157245
can anybody tell me anything with the vin??
Savannah, Georgia
Old 04-11-2010, 05:55 PM   #10
clinebarger
1GCHC33W2ES157245
700R4s didnt come in 1ton trucks or behind big blocks. Stock 700R4/4L60s do not like abuse & the throttle valve cale ajustment & geometry is critical. Small & big blocks have the same bellhousing bolt pattern.
clinebarger is offline   Reply With Quote
Old 04-11-2010, 08:53 PM   #11
lurch115
lurch115's Avatar
700's were in alot of vehicles. camaro, impala, caprice, delta 88, s-10s, and just about any chevy or gmc pickup from the 80's that has overdrive in it. if you are looking at the trucks make sure you are looking at '93 and earlier. '93 was the first year for the 4l60e which is the electronic version of the 700 and they both have the same pan on them.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 04-11-2010, 09:17 PM   #12
bucannon
Salty Sailor
bucannon's Avatar
but this truck had the rectangular transmission pan
Savannah, Georgia
Old 04-11-2010, 10:39 PM   #13
bucannon
Salty Sailor
bucannon's Avatar
can someone look up the VIN and tell me what transmision this truck has??????????
Savannah, Georgia
Old 04-11-2010, 11:15 PM   #14
camshaftgsxr
camshaftgsxr's Avatar
700's are generally geared lower in first and have a nice lil over drive gear.. and the tendency to grenade quite often... mine is doing great after 200,000 miles and at least one rebuild thought and its ALL IN THE TV CABLE
DO NOT, I REPEAT DO NOT DRIVE ONE UNTIL THE THROTTLE VALVE (TV) CABLE IS ADJUSTED PROPERLY!!!! YOUR TRANS WILL LAST YOU ABOUT 500 MILES (IF YOUR LUCKY)
if its totally square its a 700r4 if its got a corner "cut" off it is a th350
my guess sounding from the truck i would say a th400... but i'm far from a trans expert that is just gm's heavy duty trans
camshaftgsxr is offline   Reply With Quote
Old 04-11-2010, 11:58 PM   #15
Captainfab
60-66 Nut
My guess would be that it's a TH400 since it is in a C30, unless someone put a different trans in it. Here is a link to help you ID a TH400.....
http://images.google.com/imgres?imgu...26tbs%3Disch:1
Old 04-12-2010, 11:43 AM   #16
DjS71
Pick up the phone and call your local Chevy dealer, if they are worth their salt they should be able to nail it down for you. I think they go back to '85 or so.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 04-13-2010, 08:04 PM   #17
bucannon
Salty Sailor
bucannon's Avatar
okay yea the rear end of the c-30 it is out so its on the ground and it has step bars on the sides so i can only look under it from the front and it has a "corner cut out" on the front passenger side. that sounds like a 350 right?
as for the 80's oldsmobile cutlass supreme i found that looks like it had a 700r4, i looked up the vin online and found out it originally had a 3.8 v6 with 2bl carb. i looked under the hood and i know it has a small block with a 4bl and it looks factory with the power steering and a/c setup, but obvoiusly not. so whoever swapped the motor on this thing could have put a 700r4 in it.
Savannah, Georgia
Old 04-13-2010, 09:41 PM   #18
clinebarger
Heres some pan configurations. The Olds chould have a 2004R or a metric 200 who knows? If it has a metric 3speed transmission thats why its in the boneyard
Old 04-13-2010, 10:00 PM   #19
LEEVON
LEEVON's Avatar
you want an 88-92 700R4. Earlier ones are weak and shift poorly. Here is how to identify these:
http://www.hotrodders.com/articles/T...ification.html
Also, if you're not sure because the numbers are all greasy the later ones have a "vein" running up midway on the case. Also, you want one with the cable speedometer tailshaft. I switched one in the yard.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 04-14-2010, 10:20 AM   #20
southside_jon
southside_jon's Avatar
http://www.rowand.net/Shop/Tech/Auto...issionSwap.htm
Check out this web site. It's got some good info on your swap. TH350 to a 700R4. Looks like the guy did his homework.
1987 GMC Crew Cab R2500 2WD.
1954 Olds 88 2DR.
1963 Impala 2DR Sports coupe. (has been stolen)
2006 Harley-Davidson Sportster
1994 Camaro, V6 (Wife's)
southside_jon is offline   Reply With Quote
chevy, mopar, small block, transmission
