Old 05-08-2010, 06:40 PM   #1
low88burb
monster transmissions are junk
i paid 1600 for their stage 2 and it sucks . my stock turbo 350 in my malibu wagon shifts as good or better and its not new . im thinking they took my 1600 and sent me a stock 700r4.i spent $40 for one of their tv cables it was used and woulndstay ciped in the bracket so i had to go to napa to get a stock type. all this and i had to wait a month just to get it from them when they said it would be 2 1/2 weeks . very dissipointed with them.
low88burb is offline   Reply With Quote
Old 05-08-2010, 07:35 PM   #2
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: monster transmissions are junk
Be sure the tv is adjusted right. It is critical for shift quality and timing. That being said I have no opinion and have had no dealings with monster. jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-08-2010, 08:57 PM   #3
85burb
85burb's Avatar
I have same trans in my 85 700r4 stage 2. with 1800-2000 stall converter. Mine will hurt your neck if you punch on it. Def will bark tires in 2nd. Maybe 3rd if had less weight. Check you tv adjustment. It is vital to shift patern and firmness. Try taking it to a good trans shop. One adjusted mine for free. If it does not help call them back. They are very friendly. They will try to make it right. They sent me a 100 part cause mine did not have a computer so i needed a diff lock up kit. They did not argure or anything.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-08-2010, 11:23 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
I agree with 85burb, Give them a chance before you bash them. I've had no issues with my Mega Monster TH350 with 2000 stall.
I drove 3 hrs and picked mine up in person, They gave me a tour of their rebuild shop and shot the bull for over a hour, Really good guy's in my book....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-08-2010, 11:35 PM   #5
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
I have to agree with everyone else, i put one of their 700r4 and converters in my impala and the motor is 580hp to the flywheel and i have also sprayed a 150 shot of nitrous and nothing, it holds like a champ! Sad to say but you bashed them when the problem might of been the installer/adjuster of the tranny. They are a good company with a great rep, they try to keep it that way and im sure will help you with any questions and concerns you might have.
staggerd86c-10 is offline   Reply With Quote
Old 05-09-2010, 08:19 AM   #6
85burb
85burb's Avatar
That makes me feel good. I am building LQ4 that will hook to mine should have about 500.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-09-2010, 10:34 AM   #7
SSC's76
No No
SSC's76's Avatar
A well built transmission even a "stage 2" isnt going to shift much harder then a stock transmission under normal driving conditions. The idea is to have a firm quick shift with no delay. I'm sure monster uses a transgo kit or a variation these kits keep the shifts fairly stock until you romp on it or manually shift. I looked at the website. This isnt much more then a stock rebuild with upgraded parts to handle a bit more power no where in the description is it listing as a neck snapping setup, its built to be like stock but better. I cant say why they would send out a used cable but I'd be calling and asking.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 05-09-2010, 02:23 PM   #8
low88burb
you guy are hopefully right. it was one of thoughs nothing works right installs . sorry for my blow up
Old 05-09-2010, 11:11 PM   #9
85burb
85burb's Avatar
Belive me i felt same way. The same day i installed trans my electric fuel pump went out. The factory mechanical could not suck fuel threw it that good. So if you punched it it would be ok then crap out and make trans feel like it was slipping and jerking. Took a few weeks to figure that one out. I also had 3 different shops adjust my tv cable. First one was way to late on shifts second one was way soft early shifts. It was in od at like 25 MPH. The last one did it great. Take deep breath and look over everything again.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-20-2010, 12:09 PM   #10
D O C
everybody still happy with there transmissions?i'm gonna get a rebuild kit for my 700r4 k case 4x4 1 ton burb project
D O C is offline   Reply With Quote
Old 11-20-2010, 12:44 PM   #11
low88burb
mine works great i goy my new tv cable from napa it worked way better than the 38 dollar one i gat from monster . there tramissions are good though
