Old 05-12-2010, 01:16 PM   #1
rcbildr
rcbildr's Avatar
TH-400, No reverse, what to check???
The TH-400 in my diesel burb won't shift in to reverse. Is there anything I can check or is it time for an overhaul? Any help will be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 05-12-2010, 02:23 PM   #2
z3pr68138
z3pr68138's Avatar
Re: TH-400, No reverse, what to check???
First thing I check is the trans dipstick. Low fluid or brown and burnt smell are dead give aways.
1987 Chevrolet K5 Blazer with 1990 GMC Suburban front clip
z3pr68138 is offline   Reply With Quote
Old 05-12-2010, 06:05 PM   #3
knightowl73
TUKE-NoBullChit Customs owner
knightowl73's Avatar
bad thing is 1sr and reverse are the same clutches inside, so most likely if you dont fix it first will be the next gear to go out. has happened to me before but my trans was too far gone and before i could really even try to figure out if it was something simple, 1st went out as well. my dad says its common. when we rebuilt it, clearly the clutches for 1sr gear wear shot. neve had a prob after that.
OWNER @ NBC Customs...No Bull Chit....'92 GMC C2500 ECSB 350/TH400, '57 FORD SKYLINER (My dad's for now, but its really mine-you'll NEVER see a cooler car at 7 years old lol), '42 ford rat rod shop truck (new project), 91 CHRYSLER VOYER MINIVAN (shop van for now)
http://www.facebook.com/#!/nbc.customs
knightowl73 is offline   Reply With Quote
