Old 05-19-2010, 04:20 PM   #1
71 burb
frontend
i'm fixing to get my 59 apache back soon and my question is about the frontend swap what is the cheap,eaziest way to do it i want to know what is the cheapiest eaziest ;middle of the road swap far as money and time and also about the swap kits you get through fatman etc i like that kind of swap but not the money and also the ride quality on different setups i would like to go with bags thanks jason
71 burb is offline   Reply With Quote
Old 05-20-2010, 06:58 PM   #2
71 burb
Re: frontend
ok if i was going to use a camaro front clip what years are best
Old 05-20-2010, 09:11 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: frontend
Anybody?
--Josh
Old 05-20-2010, 10:38 PM   #4
blackdiesel
blackdiesel's Avatar
Re: frontend
as for the camaro year that would be 70-81, firebird is the same as well. I did the weld in cross member with tubular a-arms. Check out my "project 2 wheel drive" on down the page if you would like to see pix.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 05-21-2010, 08:59 PM   #5
mobileortho
mobileortho's Avatar
Re: frontend
Another alternative is the 73-87 half ton IFS. It's a simple bolt on affair & should be an easy & inexpensive swap for you truck. I used one on my AD but had to have it narrowed to fit my frame. If I'm not mistaking your's being wider, it should bolt right up.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 05-22-2010, 05:17 AM   #6
71 burb
Re: frontend
thanks that was done to my 70 burb when i got it i'll look in to that when i buy my truck back next friday i didn;t even think of that! thanks jason
