Old 05-22-2010, 01:25 AM   #1
code4
Door Glass
Well our project "junker" is on the road. We are hoping to go on the power tour with it. It is a 54. We attempted to put new door glass in it yesterday & dayum! How the heck do you get it in there? Any advice would be greatly appreciated, time is getting short.
code4 is offline   Reply With Quote
Old 05-22-2010, 01:39 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Door Glass
post a little more detail on what your having problems with.
dwcsr is offline   Reply With Quote
Old 05-22-2010, 02:53 AM   #3
code4
Re: Door Glass
I can't get the door glass to fit inside of the slides. I tried to remove the vent window assembly & a few other methods but couldn't get it to fit.
I will try some more but I thought mabye someone in here would have some tips.
Old 05-22-2010, 07:49 AM   #4
Richard H.
Spanked once
Richard H.'s Avatar
Re: Door Glass
Look here..
http://chevy.oldcarmanualproject.com...uck/index.html
The ole 350 budget build.
Richard H. is offline   Reply With Quote
Old 05-22-2010, 01:49 PM   #5
code4
Re: Door Glass
Originally Posted by Richard H. View Post
Thank you so much richard, that link is awsome.
Now I have to get back to work, 2 weeks left.
Old 05-23-2010, 02:06 AM   #6
silversvs
Re: Door Glass
Don't know if the 54 is the same as my 59, but I just replaced all the door glass this evening. I pulled the vent assembly most of the way out and then slid the window glass in at an angle. I then slid the window glass and vent assembly down into the door. I wiggled the vent assembly into place. Then used the window crank to put the regulator up where the sash upper channel was visible. Then I instaaled the two retaining screws and I was done. Sounds easier than it was but it only took about two hours start to finish to replace all the glass.
silversvs is offline   Reply With Quote
Old 05-23-2010, 01:44 PM   #7
OrrieG
OrrieG's Avatar
Re: Door Glass
When I've replaced window glass I've pulled the vent part way out too. I think you might have to pull the door unlocking handle and rod too.
OrrieG is offline   Reply With Quote
