05-22-2010, 11:51 AM | #1 |
Power Window Sources??
I've found 2 sources: Specialty Power Windows (universal kit) or Electric-Life.
The info I've found via 'search' was limited. Anyone care to share their experiences w/either of the above products?
05-22-2010, 01:07 PM | #2 |
Re: Power Window Sources??
Scoti I`ll be watching this as well, I did run across this...http://www.a1electric.com/spal.htm
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip Last edited by Rich 5150 69; 05-22-2010 at 01:57 PM. |
05-22-2010, 06:19 PM | #3 |
Specialty power windows are the best kit out there very complete and we have been
using for years at our shop.On top of that we are a dealer and have them in stock and we have some good prices on them for truck board members. Justin |
05-22-2010, 07:06 PM | #4 |
Agree with the SPW windows and products. We are not dealers for their products but they are top flight. We have installed their window kits and wiper kits on these years. All quality and they are very nice people.
05-22-2010, 09:04 PM | #5 |
I have electric life in my truck. They are ok. I didn't like the fact that I had to drill holes at the bottom of my doors. It wasn't a biggie seeing I had the Rod Doors door panels. Other then that they work just fine.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-22-2010, 10:17 PM | #6 |
"Where were you in '62?"
1955-1963 Truck Front Door Power Window Kit, Trucks With Vent Windows, Switches ...
Price: $375.88 http://www.bobschevytrucks.com/1955-...with-vent.html And here: 1955 - 1966 (Specify Year) Power Window Kit - Partial Kit does not include switches, wire harness or flexible wire conduits. http://jimschevroletparts.com/uploads/55-66Truck.pdf http://www.a1electric.com/catalog/cat_chevtruck.htm http://www.thehoffmangroup.com/autol...c=powerwindows Also look here: http://67-72chevytrucks.com/vboard/s....php?p=3768123
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 05-22-2010 at 10:24 PM. |
05-22-2010, 10:45 PM | #7 |
I just went to the Specialty power windows site but didn't see an application for 60-66 chevy trucks. http://www.summitracing.com/parts/ELI-GM103-0065-K/ I think mine came with Bocsh motors. Also they are only $251 without switches though.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 05-22-2010 at 10:47 PM. |
05-22-2010, 11:47 PM | #8 |
Resistance is Futile
SCOTI......I have the Electric life kit for 64-66. I pulled it out to get ready for the install and noticed that one mounting screw is supposed to be drilled thru the door below the door panel!!! I used the guide to confirm!!???(WTF??)
I got sidetracked on my BBC install and didnt get to putting them in, but the kit may mount fine without the one screw as the other 3 screws create what appears to be a stable trianglular mounting area, IMO.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-23-2010, 10:13 AM | #9 | |
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 05-23-2010 at 10:13 AM. |
05-23-2010, 11:33 AM | #10 |
Good info guys. I definitely don't want to drill any extra holes & would prefer something along the lines of a direct swap if possible (I've got enough projects already ).
05-23-2010, 11:39 AM | #11 |
Any concerns w/the installs? Specific PITA items?
05-24-2010, 07:10 AM | #12 |
Try Nu-Relics. They make a bolt in kit for 64-66 chevy trucks (may have ealier models too). Uses GM motors and stock apearing linkages. Nice quality parts, not cheap, but bolt-in. I had a set but opted for the generic rail style for one piece glass installation.
05-24-2010, 09:12 AM | #13 |
1965 Chevy C10, 2005 4.8L/4l60
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-24-2010, 10:00 AM | #14 |
http://www.billstruckshop.com/Catalo...F%20Master.pdf
Page 28 I think. They are showing a kit for both door styles(60-63 &64-66) @ $495. Siemens motors on original style regulators. And there is the option to use the original cranks as controllers. |
05-24-2010, 12:00 PM | #15 | |
05-24-2010, 12:37 PM | #16 |
"Then I could wire in a separate hidden switch to control the pass side from the drivers seat"
That would be the most demanded feature of that setup. I wonder if they have the wiring and switch setup for it already? |
05-24-2010, 05:30 PM | #17 | |
05-24-2010, 06:12 PM | #18 |
It indicates the complete package. I'm guessing the window crank switch 'option' could possibly alter the price. I plan to call & verify....
05-24-2010, 08:31 PM | #19 |
PRICING ACCESSORIES ONLY
All prices are subject to change without notification Our Newest Product - NU-CRANKS Use your original crank handles ° $89.00 each ($178.00 pair) ° Wire Harness $30.00 pair |
05-24-2010, 11:25 PM | #20 |
To be specific.... alter the price meaning deduct X dollars for the 'standard switches' & add the more expensive 'nu-crank' switches. I already knew the price of the optional switches.
05-25-2010, 10:49 PM | #21 |
Has anyone tried retro fitting power window units from 70's/80's chevy truck/suburban into one of our trucks?
Any reason why it wouldn't work? |
05-27-2010, 06:59 PM | #22 |
I'm retrofitting my stock regulators with cadillac motors. I originally used chevy astro motors, but the cadillac motors are smaller. I have not installed in truck yet , but they work.
05-27-2010, 08:09 PM | #23 |
I've seen a couple of jobs done w/the astro set-ups but you have to work through the 'issues' which is kind of like a project. The caddy motors or maybe late model f-body stuff might be smaller & work better but I still would have the 'project issues' factor.
I'm wanting something that has brand new regulators & power motors that simply requires removing the original manual regulators (cause they're already out) & bolting the pwr stuff directly back in place. No drilling, no fabbing... On this project, I want to move forward & will pay to do so in order to keep my focus elsewhere.
05-27-2010, 11:15 PM | #24 |
I am in the process of installing one piece windows in a 66. I am using specialty power kit and auto loc switches which uses the crank like the other kit. The power kit is great only one cut to the track and two hole behind the panel and that was it. The switches mount nicely and auto loc makes a kit to control the passenger side from the driver side crank. Its just a push button switch and like 5 relays. I didnt go that route yet but I am starting to think I might.
66 C-10 almost done 06 Burb |
05-27-2010, 11:24 PM | #25 | |
