Old 05-23-2010, 02:52 AM   #1
B17CRX
B17CRX's Avatar
Drive line question
My 55 3200 came with a two piece drive line and a 4spd manual, now that I have swapped in a TH350 would it be better to have the original two piece shaft shortened or find a new one piece drive line?
-Joel
B17CRX is offline   Reply With Quote
Old 05-23-2010, 04:19 AM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Drive line question
I had a 57 3200 that came with a one piece but it had a std 3 speed. The TH350 is longer so if you wanted you could run a once piece as long as its not over 50-52 inches. It may be cheaper to shorten you original one.
dwcsr is offline   Reply With Quote
Old 05-23-2010, 01:42 PM   #3
OrrieG
OrrieG's Avatar
I'd go with the one piece, less joints to wear out. Before the current set up I had a 4 speed 1-ton rear end with center joint too. They originally came on the longer wheel base big trucks.
OrrieG is offline   Reply With Quote
Old 05-25-2010, 04:46 AM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
If your shaft isn't too long and the angles too sharp you could go with a one piece and get rid of the carrier bushing.
Take your measurements and talk to a local driveshaft shop. They can usually build a new shaft that is straighter and balanced better than the factory shaft.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
