Old 05-25-2010, 03:15 PM   #1
texas56
texas56's Avatar
Sheetmetal assembly advice?
Im getting ready to put on my back fenders, running boards and was wondering if anyone has any adive as to which order I should go in? Do I put back fenders on, then the boards and bed filler panels? Of course Im going to tape the hell out of it but I remember how hard it was to get everything mocked up and now I have to do it with paint on it. Wanted to see if anyone could tell me the easiest way.
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 05-25-2010, 05:32 PM   #2
OrrieG
OrrieG's Avatar
Re: Sheetmetal assembly advice?
I think Mar-K and maybe GMC Pauls have assembly tips on their sites. Mar-K also sells a bed assembly manual for around $12. Mines a fleetie so I can't help you specifically...
OrrieG is offline   Reply With Quote
Old 05-25-2010, 06:43 PM   #3
mbgmike
There really is not a correct way so to speak. We usually assemble the box install the wood and then add the fenders. but we have done it with the fenders on to.
mbgmike is offline   Reply With Quote
Old 05-25-2010, 06:49 PM   #4
mr48chev
mr48chev's Avatar
Having had both off and on my truck several times over the years I think it might be easier to mount the fenders and then the running boards. I wouldn't tighten the fenders up all the way until I had the boards in place though.
You should have the wood in so that you can bolt the bed to the frame properly before installing the other pieces.
Old 05-25-2010, 09:56 PM   #5
Kid
Kid's Avatar
I put my fenders on, then the running boards & filler panels last. Worked for me.. the way the running boards nest on the curve of the fender, would be a challenge to install the fenders after the running boards
Kid is offline   Reply With Quote
Old 05-26-2010, 09:16 AM   #6
texas56
texas56's Avatar
Thanks guys for the feedback! I got me some strip caulk and going to attempt to put them on tonight.
Old 05-26-2010, 12:52 PM   #7
youngrodder
youngrodder's Avatar
Out of curiosity, if you have all of your wiring and stuff to do yet wouldn't it make more sense to put the sheet metal on last? The reason that I ask is that is my approach and I am checking to make sure I am also going about it the right away.
Looking good
Marc
youngrodder is offline   Reply With Quote
Old 05-26-2010, 12:55 PM   #8
texas56
texas56's Avatar
Looking good
Marc
I prewired everything inside the frame where it wouldnt show. Everything is already done except inside the cab and the stuff under the hood which I will do at a later date. Im trying to get everything done from the cab back, then move to the front.Thanks!
Old 05-26-2010, 01:30 PM   #9
youngrodder
Smart man......I like how you are trying to divide the truck in 2 and tackle it that way. I might have to adapt a simulat apporach. That way the endless miles of wiring won't seem quite so daunting.
I'm digging the way your truck is turning out.
Good luck.
Old 05-26-2010, 02:11 PM   #10
solidaxel
solidaxel's Avatar
Thanks guys, that is todays assingnment, Good Review!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
