Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 05-25-2010, 10:45 PM   #1
wayfastwhitey
right below above average joe
wayfastwhitey's Avatar
08 silverado + ZEX
so if the zex manual says retard the timing on the truck four degrees. the hand held tuner for this truck cant do that. what should i do? should i just change the plugs to a range cooler and tune it to premium fuel and keep premium in it and run it or what? it is a 75 shot we picked up for $100 plus $20 for delivery on craigslist
i flush the of weakness with mushroom clouds at hand
'95 short bed x cab c1500...
just another old truck someone else beat up, abused, hacked and didnt respect... my turn to turn it into a beat up old truck into a beat up and reliable pleasure to drive...
them- "when you gonna put an exhaust on that thing?"
me- "what do you mean? The exhaust comes all the way to the bumber and sounds great!"
them- "straight pipes isnt an exhaust man..."
me- "meh... who needs a fancy muffler when you've got straight pipes? its got a cat, doesnt resonate, and I like how it sounds, and to be perfectly honest, it makes me behave myself when I'm out and about!"
^^^ favorite conversation about my truck to date
wayfastwhitey is offline   Reply With Quote
Old 05-26-2010, 09:07 PM   #2
bighaas79
Re: 08 silverado + ZEX
i believe msd makes a digital timing retard control module to do exactly what you need for running the nitrous.
bighaas79 is offline   Reply With Quote
Old 05-26-2010, 11:15 PM   #3
clinebarger
Is this the same truck that was/is blowing transmissions? DO NOT use Nitrous while in 3rd or 4th gear YOU WILL burn up the transmission again. Nitrous is too much shock for a 4L60Es 3-4 clutch pack.
clinebarger is offline   Reply With Quote
Old 05-27-2010, 01:29 AM   #4
wayfastwhitey
the very same. but it just got some extra beef. but idk if the 3-4 was beefed up. but the builder said he put stronger bands in it. would these pessibly be it? we were intending to spray at wot through first, let out of the gas, (its a wot kit) and spray through second, then disengage the nitrous since at the end of 2nd were at 95 already and we should already be ahead of the competition if we are going to beat them at all
Old 06-17-2010, 08:22 PM   #5
85burb
85burb's Avatar
You can get the MSD 6012 box. It is for putting a carb on them but will also work with factory efi. Has a built in two step rev limiter and nitrous retard. You can also program your timing curve. But it is like 325 plus like 80 for the extra harness for the efi.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
