Old 05-26-2010, 09:06 PM   #1
silversvs
59 guage cluster question
I took the guage assembly apart to clean it up before I rewire everything. Can anyone tell me if the glass/plastic face is held in with 4 rubber/foam pieces or if it's 4 beads of some type of caulk? Both clusters I have each have 4 nasty spots of black goo. Can't tell if it was caulk or very deteriorated rubber/foam. I'm ready to put it all back together and figure I'll just lay some caulk in there, but maybe I'm missing something.
Current build http://67-72chevytrucks.com/vboard/s...=1#post3993829
'59 SB Fleetside sbc 350 Muncie M21 4 speed
silversvs is offline   Reply With Quote
Old 05-28-2010, 05:06 PM   #2
wood1
Re: 59 guage cluster question
It's old foam/rubber. Must melt over the years and it leaves the black crap you talked about. Just clean the glass/plastic with glass cleaner and razor blade to remove the black goo (don't use razor blade near the numbers). You should look for some other rope filler/foam. Talk to a glass glazer, they could help. They have clear rubber shimms that could work. I don't think you should use caulk.
wood1 is offline   Reply With Quote
