Old 05-27-2010, 12:29 AM   #1
BrianZ88chevyS
BrianZ88chevyS's Avatar
2001 chevy silverado ABS problem
Hey,, n e one know what would cause ABS to kick in @ low speeds ?? when slowing down to come to a stop, they will start kicking in ??
2001 Chevy Silverado 4x4
350 4 Barrel 5 spd Posi
BrianZ88chevyS is offline   Reply With Quote
Old 05-29-2010, 06:56 PM   #2
clinebarger
Re: 2001 chevy silverado ABS problem
You need a quality scan tool to proporly dianose your problem. You didnt mention if the ABS light is on.
clinebarger is offline   Reply With Quote
Old 05-29-2010, 09:13 PM   #3
BrianZ88chevyS
it will come on @ times,, but not for very long,, than will be out for a while before it comes on again ???
Old 05-29-2010, 09:44 PM   #4
clinebarger
Sounds like the internal ABS module power relay is giving up. Checking history codes whould pinpoint that. This is a very common problem on your truck. Go to autozone and have them scan the ABS & record the current & history codes.
Old 05-31-2010, 09:57 PM   #5
Black 95 TSI
Can Autozone pull ABS codes? I thought all they can pull is powertrain codes.
Was the truck ever in for the recall. I know down here in the states trucks in the snow belt where having problems with the front WSS. And there is a TSB on the ground under the driver door
70 C10 SWB stepside forsale
00 Silverado Z71 Sold
95 Eagle Talon TSI turbo (Hellz ya its fast)
70 Chevelle
69 firebird
10 Silverado 4x4
Black 95 TSI is offline   Reply With Quote
Old 05-31-2010, 10:36 PM   #6
clinebarger
Im not sure, I have my own scanner. Just trying to help. If your in the RUST belt im not familiar with that either.
Old 06-03-2010, 09:31 PM   #7
bighaas79
There is a tsb out for cleaning corrosion off of the knuckle at the mount point for the wheel speed sensor. Rust builds up underneath the mount point forcing the sensor farther away from the reluctor wheel, creating too much air gap, which in turn changes the amplitude of the signal being recieved by the ebcm. The ebcm reads this as wheel speed difference and applies abs to correct a slippage problem that isn't really there. If possible it would still be a good idea to have someone who knows what to look for hook up a scan tool to make sure that is the problem .
bighaas79 is offline   Reply With Quote
Old 06-04-2010, 12:25 AM   #8
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
A cracked reluctor ring will also cause the ABS to cycle when coming to a stop at slow speeds. Most often exaggerated over rough surfaces as the speed signal suddenly drops out. It is usually a front reluctor ring that is the culprit. Don’t be surprised if there are no ABS codes and no ABS light.
DirtyLarry is offline   Reply With Quote
