Old 06-29-2010, 12:14 PM   #1
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
Year compatibility for doors....
I'm sure I'm not the first to ask this, but I can't seem to find it on a site search.
What are the differences between the doors for the various years? I know the 1972 model has the additional screw and dimple below the wing windows, but is that the only difference? Are all the panels compatible?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 06-29-2010, 12:20 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: Year compatibility for doors....
'72 door handle hardware and window regulator are different for the thicker '72 door panels. I believe '67 exterior door handles are slightly different in how they mount to the doors then the other years. The '67-'71 door panels are basically all the same.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-29-2010, 12:26 PM   #3
cedorris
cedorris's Avatar
So if I'm using the hardware from my 72 doors, and the shells from say a 69 everything would match up and the Super Cheyenne panels would fit?
-Clayton
Old 06-29-2010, 01:19 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
The way the '72 panels attach to the doors is different then the earlier models. I don't remember the exact difference though, I haven't had my '72 in quite a while. Someone who knows for sure will chime in I'm sure.
Beat it to fit,
Old 06-29-2010, 02:35 PM   #5
cedorris
cedorris's Avatar
Do you know if it is something that can be drilled out to fit?
If anyone can answer this... you'll get 25 points!
-Clayton
Old 06-29-2010, 07:16 PM   #6
sameyrasmea72
sameyrasmea72's Avatar
You can drill the eight holes for the 72 door panels clips. One problem you might run into is that on a non 72 door the are 4 threaded nuts along the bottom that are used to attache 67-71 door panels. I am not sure if these are in the same location/very close to the area that you need to drill the holes for the 72 door panels.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 06-29-2010, 07:18 PM   #7
ray_mcavoy
Hi Clayton,
Yes, I'm pretty sure you could drill the earlier year doors to accept the 72 panels.
The 67-71 panels attach with screws. While the 72 panels attach with plastic fasteners that simply push into round holes drilled in the door.
ray_mcavoy is offline   Reply With Quote
1972, doors
