Old 07-14-2010, 11:46 PM   #1
dwcsr
Hollister Road Co.
dwcsr's Avatar
Fuel pumps
What year did they change from a non return type pump to a return type pump? I've got a 2000 and not sure which pump to use on it. Its a drive by cable motor
dwcsr is offline   Reply With Quote
Old 07-15-2010, 12:21 AM   #2
clinebarger
Re: Fuel pumps
On a truck engine they went to returnless fuel system in 04, 99 on Corvette & Camaro.
clinebarger is offline   Reply With Quote
Old 07-15-2010, 09:23 AM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Fuel pumps
And the easiest way to tell is..... if there are two fuel fittings on the fuel rail, you will need to run a return line. If there is just one fitting, it is a returnless style, no return line from the engine is needed.
Which style you have will make no difference on what pump you use. If you have a returnless system, you will just need to use a Vette filter/regulator. This is a combo fuel filter and a fuel pressure regulator that has a return outlet back to the tank built in to it. WIX part #33737.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-15-2010, 09:46 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Fuel pumps
Thanks,
Old 07-20-2010, 09:50 AM   #5
Jim_PA
Re: Fuel pumps
I'm switching to returnless because hopefully an aftermarket intake will be in my future someday, and I don't want to re-plumb the fuel system if that ever happens.
Jim_PA is offline   Reply With Quote
