07-16-2010, 03:52 PM | #1 |
No Nonsense
1976 K5 on 39.5 Super Swampers
Well I went ahead and traded my C10 for this 1976 K5.
350 / 350 NP203 Dana 44 / GM14 full floating 3/4 ton axles 6" lift and 3" body lift 39.5 Super Swampers She needs some cleaning up and personalizing......... I can't wait til this 103 degree heat dies down. Here she is: Last edited by Libertad; 07-17-2010 at 04:41 AM. |
07-16-2010, 03:58 PM | #2 |
No Nonsense
Re: 1976 K5 on 39.5 Super Swampers
Interior pics:
and the motor: |
07-16-2010, 04:07 PM | #3 |
Very nice!. I am glad to see you went threw with the trade.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
07-16-2010, 04:10 PM | #4 | |
No Nonsense
Yeah me too! Thanks!
Bi-Centennial Blazer |
07-16-2010, 09:04 PM | #5 |
Nice truck, Whats the plans?
06' GMC 1500 Crew cab..... |
07-17-2010, 02:18 AM | #6 |
No Nonsense
Well Gemp as for right now:
-replace a 24" brake line on the front passenger side -go through every piece of the suspension and undercarriage to make sure their ain't any loose bolts -get it registered in my name -take her out in the local hills and try her out But in the future I will be doing a 4x4 K5 version of a 70's type rat rod. I got some things in mind that will personalize her into a bare bones type of no nonsense all terrain vehicle.
07-17-2010, 07:06 AM | #7 |
I think you did well.Solid rig, just needs your touches.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
07-17-2010, 01:45 PM | #8 |
Eewww, no steering stabilizers. I can't imagine how that thing feels going down the road.
Other then that, cool truck. I have a soft spot for K5's, I've always loved them. |
07-17-2010, 02:24 PM | #9 |
No Nonsense
What type do you recommend and how tough is it to install?
07-17-2010, 02:58 PM | #10 |
I ran Pro Comp stabilizers on my 91. There's a ton of different brands out there. You can probably check 4 Wheels Parts. After installing them on my 91 it was 1000x's better. It nearly stopped the wandering and drifting it was doing without them.
They're pretty simple to install also, not hard at all. It's amazing how many lifted K5's I see without them. |
07-17-2010, 03:14 PM | #11 |
Here an old picture of my 91, I ran the over under style stablizers....
I've heard people say the end to end style are better, but I don't know. |
07-17-2010, 03:36 PM | #12 | |
No Nonsense
07-17-2010, 07:01 PM | #13 |
Make sure crossover steering is on your list, that will help you out way more then a steering stabilizer will.
That draglink is at a steep angle right now. Also, get a ORD style steering box brace and find a XJ steering shaft to swap in, all of these things make a world of difference. Blake |
07-18-2010, 03:27 AM | #15 |
Sweet!
77 k5 2wd 76 k5 jimmy 4x4 97 c1500 2wd 06 chrysler 300 on 22"s |
07-18-2010, 08:59 AM | #16 |
With that big of a tire the dana 44 can and will be a weak link in the drivetrain. Not trying to scare you, but keeping that in mind and taking it easy when you are a ways from pavement will help you make it back.
68 stepside 76 blazer 86 Silverado 07 Sierra Z71 17 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
07-18-2010, 11:37 AM | #17 |
^^^Russ is right about the Dana 44, I destroyed the one in my Jeep and it only had a 35" tall tire. They are not very friendly with the heavy wheels and tires .
Thing looks like a ton of fun though! I'd fix the air, straighten out the steering and drive the snot out of it |
07-18-2010, 11:52 AM | #18 | |
Installing one though is no small task. I remember the that took longer then doing the whole lift kit on mine. |
07-18-2010, 12:09 PM | #19 | |
No Nonsense
I will mostly be doing the local hills around here and nothing crazy fast or hard.
07-18-2010, 12:19 PM | #20 |
No Nonsense
Adding steering box brace.......thanks
07-18-2010, 02:32 PM | #21 |
The 1/2 at 3/4 are internally the same, basically the only difference is the lug pattern. Some people have had good luck with them and a lot of upgrade parts are available, such as chrome molly shafts. Its not a bad unit, just not as strong as a 60, but it is suppose to be stronger than the 10 bolt. I do want to add that it is a very sharp truck and I am curious how the handles between the top and door get attached, I would like to add them to my 76.
68 stepside 76 blazer 86 Silverado 07 Sierra Z71 17 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 Last edited by russgt; 07-18-2010 at 02:34 PM. |
07-18-2010, 02:50 PM | #22 | |
No Nonsense
BTW Russ I checked out your 76 build and man you put a lot of work into it. Looking great! I can't believe how much rust kills in the North.
07-27-2010, 03:29 AM | #23 |
No Nonsense
Well painted the K5 more to my liking. Marine Corps Olive Drab and Black. OOOORAH!
07-27-2010, 10:22 PM | #24 |
looking good
07-27-2010, 10:55 PM | #25 |
What happened with the satin black? Looks good.Was the dolphins plate really worth keeping though LOL ? My Jimmy is sport'n A Seahawks frame.
