Old 07-17-2010, 02:02 AM   #1
RaysK20
Temp and fuel gauge wiring
Here is the deal, the temp gauge and fuel gauge were working just fine up until a few days ago. Now when you you turn on the head lights the temp gauge creeps all the way to full hot, and the gas gauge drops to quarter tank even when its full. You can turn the truck off and when you restart it the temp gauge returns to normal for a few until it goes full hot. The gas gauge has quit reading anything now but a solid half tank. I am not very good at wiring, but not hopeless. Anybody care to point me in a direction here. The truck is a 73 K20 for the record. Thanks for any help.
RaysK20 is offline   Reply With Quote
Old 07-17-2010, 02:17 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Temp and fuel gauge wiring
Start by checking ALL grounds on the vehicle; at the tank, the H/L switch, every wheres inspect, clean, and reconnect.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-17-2010, 02:05 PM   #3
RaysK20
I just got done cleaning the grounds under the hood above the head lights and the ground for the fuel tank. The only other ground I could find under the dash was mounted to the Ebrake bracket. Where does the light switch ground? So far no changes. Is there a fuse that controls the tank gauge? All the fuse look good though.
