Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 07-27-2010, 09:19 PM   #1
bigrigpardo
wtb 4x4 shifter handle and box assembly.
i have a 70 jimmy with a 4x4 shifter the shifts kinda like a J. the handle goes into a box that has a trac to control were the rod goes. mine is shot. trac rotted and is extremely hard to find gears. i need a handle box and trac?? i will ad pics tommorow.
bigrigpardo is offline   Reply With Quote
Old 07-27-2010, 11:04 PM   #2
sharpie1972
Re: wtb 4x4 shifter handle and box assembly.
Pictures would be very helpful. Do you know if you have a Rockwell or New Process 205 transfer case? I have shifters for both. Glad to help if I can, Sharpie
sharpie1972 is offline   Reply With Quote
Old 07-27-2010, 11:05 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm guessing he has a rockwell by what he is describing and what parts are left in my 69 with the rockwell.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-27-2010, 11:07 PM   #4
sharpie1972
I agree, I guess we'll wait for pics to confirm! Sharpie
Old 07-29-2010, 08:35 AM   #5
duallyjams
duallyjams's Avatar
it sounds like it is a rockwell but didn't gm switch from a rockwell (69) to np205 in 1970 also rockwell were all manual trans.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-29-2010, 11:06 AM   #6
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
1970 np205 shifters are different from 71-72 np205 shifters. There is also 2 different styles of 70' np205 shifters. The one that points off to the left is more setup for a stick so they don't hit, and the automatic 70' is the one attached to the transfer case. ***Note, I have the wrong manual shifter in the pic, and is misleading on how they would hit each other. Here ya go:
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-29-2010, 11:12 AM   #7
71blksuper4x4
SWB 4x4 Collector
I also forgot to mention that if wanting to be correct on a 70' np205, you will need the correct high humps, the holes are cut differently for the np205 shifter in 70' as the shifters are bent more at the base to allow the transfer case shifter to line up centered with (if manual) the manual shifter hole. The 71-72 np205's are more offset to the passenger side of the hump. Trevor
TREVOR
Old 07-29-2010, 11:14 AM   #8
71blksuper4x4
SWB 4x4 Collector
Here is a couple of pics of a Dana 20 setup, typically found in blazer's in 69, and not sure if they came a in a select number of 70's. Trevor
TREVOR
Old 08-01-2010, 06:32 PM   #9
6t727t2
Active Member
Have this one, out of '69 blazer w/rockwell, $45 shipped
6t727t2 is offline   Reply With Quote
