07-29-2010, 12:46 PM | #1 |
Future TOTM Winner
Let's back up a bit...wiring harness basics?
I am still on the fence about whether to re-work my original harness or send it off to someone. I am a pretty good DIYer with an electricians background so circuits and wiring are nothing new to me. My question is this, for your regular run-of-the-mill LSx swap, what sensors or connectors are needed? Obviously, I know about the major ones, but some seam to be in a grey area and that is very confusing to a person in my situation. Another way of looking at it is, how many connectors should be on a re-worked harness. Maybe we can keep the answers in somewhat of a specific formula...
Connector/Sensor Name, Required/Suggested for best results, Needed for emission, Needed for auto tranny I'll start with an obvious one... Throttle position sensor, required, all, all tranny setups Hopefully this makes some sense. I have been looking for this info all over the web and nobody has it listed this clearly. Please help me fill in these blanks.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
07-29-2010, 11:02 PM | #2 |
Future TOTM Winner
Re: Let's back up a bit...wiring harness basics?
No one wants to play along??? I thought this would be fun and informative for the whole family.
07-30-2010, 12:34 AM | #3 |
GM ONLY BABY!!!
There's a lot of diagrams and info about this in the "How to swap LS series engines into almost anything" book. As for me I amgoing to send mine to John at www.speartech.com.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
07-30-2010, 12:56 AM | #4 |
Future TOTM Winner
I have that book and while I wouldn't call it worthless, it's not near as informative as I was hoping. Most of the info that I see is geared more towards the LS1s and other "car" engines. Obviously a lot of it is good for all the LS engines, but the detailed pin outs and charts etc by-and-large were not for the LSx series.
07-30-2010, 06:01 AM | #5 |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 Last edited by Thealien; 07-30-2010 at 06:02 AM. |
07-30-2010, 08:19 AM | #6 |
Well, let me think. I'm going MAF-less, here's a list of everything I have (T56/LQ4)
IAT (trucks have maf/IAT in the same plug, so I had to separate mine) Throttle body (DBW) Front O2 sensors Knock sensors MAP sensor Temp sensor Injectors Coils Crank sensor Cam sensor Alternator Oil pressure VSS sensor I think that's all I'm using. |
07-30-2010, 07:12 PM | #7 | ||
Future TOTM Winner
I guess I am to the point where I need to just pull out my harness and start dissecting it, been trying to to all the studying first before I dove in. Quote:
07-30-2010, 08:34 PM | #8 |
Next project: 1970 K10
Just for refernce, this is what is left on my harness after W4M reworked it:
2006 Silverado harness, starting at PCM connectors and moving out from the PCM - BARE WIRES: White - To tach, 4cyl signal Green/White - To fuel pump relay control, 12v + White - To brake light switch, cruise Purple - To brake switch, for TCC Green/White - VSS, to speedo Green - To OBD II connector, in vehicle Brown/White - To SES light 3 Red wires - Each to a 12v key-on fused power source 1 Orange wire - To a 12v battery fused power source 1 Purple wire - To starter solenoid (tie trucks starter wire to this one, or leave it alone and use trucks wire to the starter) CONNECTORS: • Electric fans (high and low, I will have to supply the ground) • TAC module • Wires for cruise: Dark Blue, Gray/Black, Gray • DS coil packs • DS injectors • Alternator • Coolant temp sensor (front of left head, for PCM) • Ground • Starter solenoid (see “1 Purple wire” above) • Crank sensor MAIN HARNESS SPLITS IN TWO HERE: One: • MAP sensor • Passenger side O2 sensor, front • MAF • PS coil packs • Ground • PS Injectors • Throttle body Two: • Knock sensor harness on intake manifold • Oil PSI switch (behind intake manifold, for PCM) • Cam sensor • Ground • Driver side O2 sensor, front • Transmission, drivers side • Transmission, VSS, tailhousing • Transmission, passenger side
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-30-2010 at 08:36 PM. |
07-30-2010, 10:10 PM | #9 | |
WIRES THAT ARE NOT HIGHLIGHTED REMAIN UN TOUCHED. THEY WILL GO DIRECTLY FROM PCM TO A PLUG, (SENSOR, SWITCH, DEVICE ETC.)
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-30-2010, 10:50 PM | #10 |
Future TOTM Winner
Sorry, I'm blind!
08-01-2010, 11:32 AM | #11 |
Critter, I am in the process of doing it now, and it makes a lot more sense once you start tearing into the harness and see the actual wires that they are talking about. I have three of the pages from the lt1swap page open and am referencing them all as I go along. It is really not as bad as you would think. I also come from an electricians background so I know what you are saying. It seemed much more daunting before I started. Of course I won't know if I did it right until I go to plug everyhting in and it either starts up or does nothing!!
