Old 08-01-2010, 04:04 PM   #1
Psycho71
Psycho71's Avatar
'02 ford 8lug wheels?
I have read that the newer ford 8 lug wheels will not fit chevy's 8lug. Where's the breaking point for this?
I found a set of wheels for sale, off of an '02 (i think they said) ford truck. I have an '85 burb 3/4 ton. I called the fella, he measured the wheels out a 8x6.5" bolt pattern, and the center hole on his is 4.75", all the same measurements as mine. Any reason these won't fit on my burb?
Thanks,
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 08-01-2010, 09:08 PM   #2
mod58
Re: '02 ford 8lug wheels?
98 or 99 and up ford won't fit,The ford pattern is 8 on 170mm.It's very close to 8 on 6.5.You can easily make a mistake when measuring thats how close it is!!Hope this helps!!!
mod58 is offline   Reply With Quote
Old 08-01-2010, 10:01 PM   #3
Psycho71
Psycho71's Avatar
That's what I wanted to know. The wheels are 1.5hrs from me, and I had the owner of them measure them. He came up with the 6.5" bolt measurement, but I bet they are the metric measurement and he's just not seeing that on a tape measure.
Thanks, saved me a drive out there to measure them myself. But it does kinda blow that ford did that. I could have me a nice set of wheels for cheap. LOL
Old 08-01-2010, 10:41 PM   #4
USSkoval
The changeover happened with the super duty trucks. The van kept the regular 8lug pattern, maybe even up to current.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
