Old 08-02-2010, 07:39 PM   #1
Murphy IRE
"D" Shackle mount for front bumber
I have the std OEM chrome bumper. I have a Ramsey 8000 lb winch bolted to the frame behind the bumper. The opening is directly behind the frt license plate (old gas fill hinges). I want to use a Snatch block for increased pulling, but I don't have anything to attach to. Is there a system out there that bolts on to the front using longer bolts?
Murphy IRE is offline   Reply With Quote
Old 08-02-2010, 08:00 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: "D" Shackle mount for front bumber
Will some original tow hooks work? Or are those holes taken by the winch?
How bout some CUCV shackle mounts?
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 08-02-2010, 08:31 PM   #3
Murphy IRE
Original holes now have 1/2" bolts in them for the winch. CUCV shackle mounts??? Would they bolt onto the bumper with new longer bolts?
Old 08-02-2010, 09:29 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
No, You would have to cut a square hole in your bumper, then bolt them directly to your frame. Look at the front of a M1008 army truck, you will see what i'm talking about.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-03-2010, 03:37 PM   #5
OrrieG
OrrieG's Avatar
whatever you decide to do make sure you have a pulling point on each frame side and use both of them. lots of bad things can happen pulling on one side only, usually relating to bent frames. youtube has tons of videos on how not to pull from one side, most pretty funny to us, not so for the person that owns the truck or car.
OrrieG is offline   Reply With Quote
Old 08-04-2010, 10:51 AM   #6
fun in dirt
fun in dirt's Avatar
Here is a few pics of the CUCV mounts...they bolt to the frame & stick through the bumper. These are on an '87 but could probably be made to work with a 1st gen without too much trouble.
A guy called & said he wanted to buy them so I took them off & even took pics so he could see how it all mounted, then I never heard from him again
Anyway if you decide to go this route I can hook you up.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 08-13-2010, 10:44 AM   #7
Murphy IRE
Here are some pics. As you can see the winch eats up a lot of room. Either I get a custom made bracket to fit on the bumper or through it ( I think it might cost more than I want) or get some big hooks bolted (or welded) on the frame. Again there isn't much room for the hooks. Any sugeestions???
Old 08-13-2010, 03:02 PM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
It looks like there's room between the spring mount and the single 1/2" bolt.
I put the newer style hooks (73-87) on my Blazer in that spot.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 08-17-2010, 05:43 PM   #9
monza1979
monza1979's Avatar
any more pictures of the winch mount? that is an awesome set up! as for hooks, you could try, if you like the look anyways, a light bar mount. you know the ones that are popular on 73-87 trucks. i have one and it works great for pulling and getting pulled.
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 08-17-2010, 10:16 PM   #10
AJs72K5
AJs72K5's Avatar
I had these made. 3/4" steel.
*EDIT: pics removed.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 08-18-2010, 10:03 AM   #11
Murphy IRE
Perfect - Nice and clean!
Did you have a metal shop fabricate them or did they already have something in their arsenal? Is that a 1/2 or 5/8 hole for the shackle? Do you or they have a layout for the design? BTW from what I can see the K5 looks great!
Thanks,
Sean
PS I owe you a cold one!!! Where in Texas?
Old 08-18-2010, 07:46 PM   #12
AJs72K5
AJs72K5's Avatar
Thanks,
Sean
5/8" bolts to the frame in the stock location of the factory tow hooks. 3/4" hole (I think) for the shackle. They were cut on a water jet by a friend who also has a 1st gen K5. These were a duplicate of a set he'd already made for himself. He works at a steel factory.
- AJ
Old 01-02-2011, 12:33 PM   #13
72longbed
72longbed's Avatar
Thumbs up Re: "D" Shackle mount for front bumber
Hey AJ,
Cool Shackle mounts!! I sent you a PM about them. Give me a shout back, I'd like to get some more info on them if I could please.
Thanks,
72longbed
72longbed is offline   Reply With Quote
Old 01-02-2011, 01:07 PM   #14
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
AJ those look awesome! How much did they cost you? Could you get us a set?
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 01-03-2011, 11:53 AM   #15
Murphy IRE
After my tranny died, I haven't had the funds for fun upgrades, but I did find a shop in Denver that will do the work for $110. That includes the CAD/computer time. Looking forward to getting them done in the Spring.
Old 01-03-2011, 10:34 PM   #16
AJs72K5
AJs72K5's Avatar
Thanks,
Sean
Originally Posted by 72longbed View Post
Hey AJ,
Thanks,
72longbed
Sorry guys. I talked to my friend who designed and made these for me. He's not willing to share his design at this time. Respecting his wishes, I have removed the main pic of them.
- AJ
