Old 08-08-2010, 01:26 AM   #1
Slowleadmccey
Slowleadmccey's Avatar
Points to electronic ignition conversion
I've got a '70 GMC and a buddy told me that I should convert the points to electronic ignition. I told him I wanted to keep the stock look of the motor so I couldn't go HEI. He responded with an explanation of the conversion kits that fit under your stock distributor. He said his Dad uses one on his fifty something truck. I saw some from Pertronix and a couple of other places. Has anyone used these things and are they as great as they make them sound? It would be cool to be free of adjusting points and such. Would anyone mind letting me know how they really are and if it's as simple as they make it sound on the web sites?
Slowleadmccey is offline   Reply With Quote
Old 08-08-2010, 01:30 AM   #2
dirtball
dirtball's Avatar
Re: Points to electronic ignition conversion
Myself and a buddy of mine are both using a Pertronix kit. Both of us were looking for a stock look and electronic reliability. Easy to install and no issues yet.
Brett
dirtball is offline   Reply With Quote
Old 08-08-2010, 01:32 AM   #3
bradley7576
i had electronic ignition on my 67 at one point but i kept have problems so i put points back on it and it fireed right up. but i have been considering going back to electronic.
bradley7576 is offline   Reply With Quote
Old 08-08-2010, 01:33 AM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I know that mallory and accel both have a kits to do the conversion for about $70 at summit (both are the same exact part they just have different labels). My dad swears by them but I haven't made the switch yet so I don't know firsthand. I think the biggest advantage would be not setting points anymore.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-08-2010, 08:25 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I switched to a mid 70's HEI.I know you're looking for a stock look but I can tell you that it
1.Made the truck start easier
2.Run smoother
3Get better milage
4 have more power
5 require less maintainence
I would definitely swap if at all possible.Even using the kit to keep it looking stock should give the same results.Don't forget to regap plugs and replace plugs and wires since it will help also if it hasn't been done.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-08-2010, 08:32 AM   #6
CJ Loeffelholz
CJ Loeffelholz's Avatar
I just ordered one and hope to install it next weekend. Did you notice any difference in gas mileage?
CJ Loeffelholz is offline   Reply With Quote
Old 08-08-2010, 09:58 AM   #7
Wrenchbender Ret
I alway's liked the Crane kit. It was discontinued a while back when they went bankrupped. I noticed in a Jeg's ad that it is available again. It is easier to install on the window type dist. then the Petronics.
Wrenchbender Ret is offline   Reply With Quote
Old 08-08-2010, 11:43 AM   #8
dirtball
dirtball's Avatar
Couldn't tell you for sure. I installed mine as I was building the truck, so no comparison. My friend switched from an HEI to this set up. He doesn't track gas mileage, but I have not heard him say he has noticed a difference.
Brett
Old 08-08-2010, 11:54 AM   #9
vectorit
What?
vectorit's Avatar
Upgraded from points to the Pertronix kit this year.
Conversion was quick and easy.
My observations so far?
Engine doesn't fire up as quick, meaning the starter has to turn a second more (I am being extremely picky here).
Plugs have a cleaner burn now.
Fuel mileage? uh, no. Forget it with these old engines. Well, at least I do because my truck is what it is.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-08-2010, 12:08 PM   #10
71 super
71 super's Avatar
I swapped points for pertronix in my bb truck and love it. Runs better, starts easy and no problems in 8 years with lots of sitting time. I have a crane unit in my 4x4 distributer- it was a little cheaper and has a built in rev limiter, have not started the new engine yet but it went in as easy as the pertronix and I expect it to perform equally well.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-08-2010, 12:49 PM   #11
gregg72340
gregg72340's Avatar
What do you do with wiring on this swap, can you just use the leads off the coil wires when you swap to the HEI? I want to do the same conversions just a lttle scared of the woring issues because Wiring harness is a spliced mess and wiring os not my strong point
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 08-08-2010, 04:12 PM   #12
Wrenchbender Ret
The wireing instucktions come with the kit. It varies with the brand. Most of them use the resistance in the circuit. The factory HEI wires directly to the ign. switch or fuse panel. It does not use resistance or bypass.
Old 08-08-2010, 04:40 PM   #13
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Mid 70's HEI here. Easier starts, better idle in the cold & damp conditions. Probably better mileage, but when you're going from 12 to 14mpg, does it really matter?
Make sure that you use a key-on 12V circuit, not one that's hot all the time.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 08-08-2010, 05:09 PM   #14
Mt Man Chad
Mt Man Chad's Avatar
Used Pertronix systems all fit under original dist cap.
http://www.pertronix.com/prod/ig/ignitor/default.aspx
Work flawlessly....
My 250 6 banger and 327 V8 both run much smooth with the setup.
$80 for the pointless system + $40 for high output coil.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 08-08-2010, 06:46 PM   #15
Slowleadmccey
Thanks for all of the input. I was probably going to go with the Pertronix one because it's the most affordable around here. It's good to know that overall, everyone is happy with them. I think I'll keep the points in the glove box just in case.
Old 08-08-2010, 08:33 PM   #16
CJ Loeffelholz
For me, going from 12 to 14 mpg would net me over $300.00 a year.
Old 08-08-2010, 08:51 PM   #17
gregg72340
gregg72340's Avatar
All i did was replace the coil from a stock one to a super coil and wound up cutting my gas milage in half
Old 08-09-2010, 11:53 AM   #18
Stock72c10
classic=of recognized value
Stock72c10's Avatar
I have the Pertronix kit and haven't really thought about it since installing over a year ago. Install was very simple, probably could have upgraded the coil too, but it seems to work great with the stock one. I would recommend it in a Chevy Heartbeat.
Stock72c10 is offline   Reply With Quote
Old 07-20-2011, 12:30 PM   #19
harv
the "SUper Coil" you mention, is there a specific one you suggest? Anyone? Thanks for all the great info on this guys, My truck is throwing a fit, back fireing out the carb once it warms up. I cant seem to get the points right.
harv is offline   Reply With Quote
Old 07-20-2011, 12:34 PM   #20
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i would keep the points and just add a msd 6 box
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-20-2011, 01:09 PM   #21
harv
what is an msd 6 box?
Old 07-20-2011, 02:26 PM   #22
fastwillie 696969
~Rest In Peace~
http://www.msdignition.com/
Old 07-21-2011, 04:16 AM   #23
Lippyp
English Chevy Owner
Lippyp's Avatar
I've just done this myself,although from a slightly different route. My truck had a dual point mallory distributor in it thanks to the previous owner and its always been a right PITA to setup and keep running sweetly. I acquired a used factory HEI to go in, bought a new module, cap, rotor and leads and then found because my engine is set well back as its on six cyl stands there wasn't enough clearance between the firewall and engine to allow the HEI to drop in the hole, simply couldn't do it. Thankfully they do a pertronix ignitor now to fit the twin point mallory so I bought one, conversion took literally 15 minutes on my kitchen table as the distributor was out as I was changing intakes and I also went for their Flamethrower coil. I've not fired it up yet as I'm waiting on some other parts so all I can say is its easy to do and fits entirely under the cap.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 07-21-2011, 07:37 AM   #24
mountainsurfer
I know it might be a little pricey, but the advantage in performance and fuel savings is worth it. You can regap your plugs out to .055 plus. I have no starting issues even when the temp is -30 here in the high country.
http://www.performancedistributors.com/gmssdui.htm
mountainsurfer is offline   Reply With Quote
Old 07-21-2011, 07:10 PM   #25
Willy Prost
My truck and I can vouch for the Pertronix electronic conversion.
It has been on the truck (250 I-6) over 25 years now.
Installed in less than 2 beers time.
No problems.
Runs smooth.
I can run the truck at 18mph in 4th all day long.
Couldn't to that with points.
Willy Prost is offline   Reply With Quote
1970, c15, conversion, gmc, ignition
