Old 08-17-2010, 03:17 AM   #1
Alaska_Ryan
305 V6 Engine Question -- Intake Manifold
I have a 305 V6 in a 69 GMC 2500. Based on the model year, mine is the 305E model The intake manifold was cracked so I scrounged another from a junkyard and model year was pre-1967 since it had the eye brow lights on the hood.
I am having difficulty getting the intake manifold to seal properly. I can hear (and see) an exhaust leak coming from the manifold. It bolts down OK and the bolts thread but just not sealing right.
1) Any one out here think a pre-67 305 V6 intake manfold might not match up exactly with my 1969 V6 305? I know the earlier 305 V6s had a different model nomeclature. For example, perhaps the one I grabbed was a V6 305C.
2) Or am I just being sloppy in put the seal down and getting the bolts to thread?
Alaska_Ryan is offline   Reply With Quote
Old 08-17-2010, 08:00 PM   #2
rsavage
rsavage's Avatar
Re: 305 V6 Engine Question -- Intake Manifold
Did you clean the thread bolt holes on the heads using a bottoming tap so the bolts can draw down? You didn't change bolts to ones that are longer did you? Those are a couple of things I can think of as possibilities. Good luck.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
305 v6, intake manifold
