Old 08-19-2010, 12:31 PM   #1
76/85 Truck
76/85 Truck's Avatar
Truck will not start with the wheel up
Hey everyone! This is probably a fairly simple question. When I have my wheel tilted to the top two notches, the truck will not start. The Battery light and Oil lights come on (like it is about to start) and nothing. Won't crank or anything. Someone I know mentioned moving the ignition switch down so the rods hit it earlier or something, but I have no idea how the rods inside the column work. Could someone explain to me how it works, and how to correct this problem? Thanks
Rich
My first truck!! 1976 Chevy 3/4 ton Camper Special and a 1985 GMC body. Has a 350, 4 BBL Edelbrock, with a Turbo 350, and NP205 T-case.
76/85 Truck is offline   Reply With Quote
Old 08-19-2010, 01:06 PM   #2
875.3CHEVY
Re: Truck will not start with the wheel up
yes moving the switch will solve the problem.the rod that moves the switch just isnt going far enough.a little adjustment is all thats needed.when your column starts to wear this starts happening.
875.3CHEVY is offline   Reply With Quote
Old 08-19-2010, 02:44 PM   #3
355bullet
355bullet's Avatar
mine does the same...i havent fixed it. kinda like a anti-thief ...hahah
355bullet is offline   Reply With Quote
Old 08-19-2010, 03:18 PM   #4
spudz
spudz's Avatar
Drop the column down and look at the rod on top going to a switch. When you turn the key it moves the rod and engages the switch. adjust it some to tighten it up. Its pretty basic. you need to get a shop manual on the truck it sounds like. it will help you alot.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 08-19-2010, 06:19 PM   #5
76/85 Truck
So just take the 2 bolts out holding the column to the dash? I do need to get a manual. I know a bit about trucks, but I've only had mine for a year (I'm 16). Mostly I need to learn about interior workings, wiring, and body work.
Rich
Old 08-19-2010, 07:24 PM   #6
76/85 Truck
I got it unscrewed the plastic part of the lower dash, and the metal part, took off two nuts holding up the column, pulled it down, loosened the ignition box, and slid it down, tightened it, and it worked!! Thanks a BUNCH!!!
Rich
column, ignition, ignition switch, tilt wheel
