Old 08-24-2010, 09:58 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
HELP Master Cylinder Frame Install 56
I bought a master cylinder that mounts to the frame rail but uses the stock pedal and some of the mounting hardware. Unfortunately I had taken all that stuff off before I went down this road (doh). I need pictures of what a stock master looks like and a completed one as well. Pictures of any type would be appreciated and i can seem to find them on the site. I have the directions (for new install) and the original parts that have been removed (in a big pile with other frame junk) but I need a starting point.
hotrod1 is offline   Reply With Quote
Old 08-24-2010, 10:19 PM   #2
fabguy
Elev8r Man
fabguy's Avatar
Re: HELP Master Cylinder Frame Install 56
I will try to get one for you tomm
fabguy is offline   Reply With Quote
Old 08-24-2010, 11:06 PM   #3
Fat Mike
Fat Mike's Avatar
I can get you a better picture tommorrow.
Fat Mike is offline   Reply With Quote
Old 08-25-2010, 11:02 PM   #4
hotrod1
56 - autocross
hotrod1's Avatar
Thanks for the pictures. I appreciate it and appreciate any other pictures you may have. People on this web site are GREAT!
Old 08-26-2010, 02:57 AM   #5
55dude
55dude's Avatar
anyone else have any pic's of a dual m/c on a task force truck? trying to do a simple upgrade for safety sake.
55dude is offline   Reply With Quote
Old 08-26-2010, 06:46 AM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
try this
from TCI
http://www.totalcostinvolved.com/ins...m?ManualID=374
or these from No Limit
http://nolimit.net/Instructions/Pwrbrkkit.pdf
http://nolimit.net/Instructions/PBC55.pdf
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 08-26-2010, 07:10 PM   #7
OrrieG
OrrieG's Avatar
Here is what I did. In 85 I build a bracket to use a 74 truck dual MC with the 4wd axles. I wanted to use the stock pedal and mounting location. This time I added onto the bracket for a booster which moved the MC. In the second photo you can see the new bracket over the original. The shaft between the pedal and booster is made up of 1/2" EMT with nut welded on one end and 1/8" stock with hole welded into a slit on the other. This is based on TCI and others aftermarket kits but with heavier stock so you don't need the cross braces and the booster support matches the booste radius.
OrrieG is offline   Reply With Quote
Old 08-28-2010, 01:46 AM   #8
bajabob
bajabob's Avatar
Orrie
Keeping an eye on this as I am planning the same deal for my truck. How did you (or do you) access the reserivor ??
bajabob is offline   Reply With Quote
Old 08-28-2010, 05:50 PM   #9
OrrieG
OrrieG's Avatar
I made this, more detail in my build thread at http://67-72chevytrucks.com/vboard/s...&postcount=135
I set my seats up so the factory tilt forward will work for access under them. They are Yukon 3rd row seats.
Old 08-28-2010, 10:25 PM   #10
entourageguy
Yellow truck club
Originally Posted by bajabob View Post
Orrie
I crawl under mine with a inspection mirror and a bottle of brake fluid with a clear piece of fuel line ....
Hey look there I am now ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 08-29-2010, 06:59 AM   #11
Russell Ashley
Russell Ashley's Avatar
That's a good one, Brian. LMAO.....
I just installed that setup on my truck. They sell an access door that you weld in, or you could make your own like Orrie did, but if you keep the original seat Brian's method seems to be the only way.
Russell Ashley is offline   Reply With Quote
Old 08-29-2010, 10:16 AM   #12
fabguy
Elev8r Man
fabguy's Avatar
Or you can try this kit that I found a while back, gonna use it on my 58 fleetside. Just trying to find a place to mount the reservoir. I am getting it from this site.I don't wanna lay on my back with a mirror or tube, lol.http://www.classicperform.com/Store/...rucks/RRCK.htm
Old 08-29-2010, 11:26 AM   #13
hotrod1
56 - autocross
hotrod1's Avatar
There is a cast housing "thing" that is riveted to the frame in front of the cab mount next to the brake system bracket. It looks like it supports a shaft of some type. What is this for? Part of the brake system. The pictures above show it (barely) but do not show if there is any brake involvement.
Old 08-29-2010, 01:22 PM   #14
bajabob
bajabob's Avatar
hotrod
Your not talking about the clutch petal pivot point are you ??? I have some pictures but they are not very detailed.
Old 08-29-2010, 01:35 PM   #15
bajabob
bajabob's Avatar
Here are a couple of shots I found. I am pretty sure that is the clutch pivot casting you are talking about.
