Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 09-19-2010, 12:01 AM   #1
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
Best Paint for Rally Rims??
I picked some up and wanted yer opinons on a paint that will last some years...
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 09-19-2010, 12:22 AM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Best Paint for Rally Rims??
powdercoat would look good if ya can afford it, other than that idk
John
1999 Toyota Tacoma 4x4
Old 09-19-2010, 09:45 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's what I used:
Krylon (Metallics) - 1403 Dull Aluminum
It's tough to find be I picked it up at O'Reilly's.
Check out this link (post #185) for an after shot with the paint on the wheels:
http://67-72chevytrucks.com/vboard/s...k+slate&page=8
Let us know if you end up using something difference, and your experiences with that product.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-19-2010, 11:50 AM   #4
Lee H
Lee H's Avatar
The correct color is argent silver, many mail order part houses carry it. Silver Alumimun Rust-oleum is very, very close and can be found at Home Depot or Lowes. Shoot a coat of clear coat and it will last a long time.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 09-19-2010, 10:24 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Unless you clearcoat the rims, use the rim paint that duplicolor sells for the different rim colors. Go to OReilly's
Frank
piecesparts is offline   Reply With Quote
Old 09-20-2010, 08:59 PM   #6
pat 70/71
pat 70/71's Avatar
the truck on my avatar has rallys & I sprayed them with silver rattle can paint & they look marvelous cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 09-21-2010, 08:28 AM   #7
cdowns
cdowns's Avatar
for a daily driver i've always l;iked rustoleum because its cheap and readily available so you can touchup easily
Old 09-21-2010, 08:56 AM   #8
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
if the rimds are a little pitted ot your not looking for hat perfect finish I used the rustoium Hammered finish and there holding up very well aftter a year of DD
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-21-2010, 03:17 PM   #9
72SWBChevy
72SWBChevy's Avatar
Originally Posted by lee h View Post
the correct color is argent silver, many mail order part houses carry it. Silver alumimun rust-oleum is very, very close and can be found at home depot or lowes. Shoot a coat of clear coat and it will last a long time.
x2
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 09-22-2010, 12:48 AM   #10
SiCk_DiAbLo
Appreciate all the tips...
1984 Chevy Z28.
Old 09-25-2010, 09:41 AM   #11
low79fx
I did like most have already stated,had them blasted ,sprayed with Krylon primer inside and out.Sprayed faces with aluminum silver then a coat of hammered finish they came out looking pretty good.That hammered silver is a pretty tough finish.Also been running almost a year.Good Luck!!
low79fx is offline   Reply With Quote
Old 09-26-2010, 08:19 PM   #12
brans72
who makes and where did you buy this hammered finish paint? Any pics?
brans72 is offline   Reply With Quote
Old 09-27-2010, 09:27 PM   #13
kev2809
low n' slo
kev2809's Avatar
i got mine at lowes, made by rustoleum i believe. i used it on my control arms and tank/compressor mounts. just make sure you prep good. i wish i would have used a primer too...but it does look good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 09-27-2010, 09:31 PM   #14
brans72
any close ups kev?
Old 09-27-2010, 09:55 PM   #15
kev2809
low n' slo
kev2809's Avatar
these are the only ones i have i think...
heres the drop spindles..
and heres the lca, with the paint can next to it..
-_--_--_ _________
Old 09-28-2010, 06:51 PM   #16
low79fx
These are the pics just as I got finished painting the wheels,right before getting tires mounted.The paint I used was Krylon bright silver for a base then used Krylon hammered silver over to finish off.
Old 09-28-2010, 06:58 PM   #17
kev2809
low n' slo
kev2809's Avatar
^^^ what did you prep the metal with (wire wheel, sand paper, blast) and did you use any primer?
-_--_--_ _________
Old 09-28-2010, 07:51 PM   #18
low79fx
Wheels were sandblasted,primered,base coated then hammer coated.Used all Krylon paint.Oh yeah,forgot to state that the wheels are painted satin black on inside and back side.
Old 01-12-2011, 02:43 PM   #19
kev2809
low n' slo
kev2809's Avatar
i know this is a little old..but is there a cheaper way other than blasting to get the rim sanded and prepped?
-_--_--_ _________
Old 01-12-2011, 03:38 PM   #20
tubbedII
needs more $$$
tubbedII's Avatar
Good old sandpaper and elbow grease...just time consuming and annoying. Blasting = more $ but less hassle/work.
.Also, we painted a buddy's 4-Runner wheels (his daily driver) gunmetal grey using the wheel paint at O'Reilly's at the beginning of the summer. We sanded, primpered, painted and cleared using all the same brand and still to this day there's no chips, cracks or peels. He even had new tires installed 3 weeks later and either the paint held up well or the tire shop took good care on putting them on
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 01-12-2011, 04:21 PM   #21
kev2809
low n' slo
kev2809's Avatar
did u sand to bare metal? im using valspar one stage black. i heard it sticks pretty damn good. i was thinking rough it up with 180, spray a few coats of primer, 400 wetsand, then shoot 2 coats of paint
-_--_--_ _________
Old 01-12-2011, 04:53 PM   #22
tubbedII
needs more $$$
tubbedII's Avatar
Nope..they were alloys so we just roughed up the top clear coat with some scotch pads, and smoothed the areas where the clear was gone and shot it. No sanding at all between any of the coats and didn't bother wet sanding the clear. The looked good though as is.
1970 2wd Blazer
Old 01-12-2011, 10:21 PM   #23
kev2809
low n' slo
kev2809's Avatar
ya i cant go that route. these older rims i believe are painted? mine are white...
i really hope i dont have to get down to bare metal...there is a lot of nooks and crannies and curves to have to get to bare metal..
-_--_--_ _________
Old 01-22-2011, 01:29 AM   #24
Telecasterjoey
Any more pics of the rims on the truck?
Telecasterjoey is offline   Reply With Quote
Old 01-22-2011, 08:52 AM   #25
Hottrucks
Hottrucks's Avatar
hey Kev try taking your wheels to your local head stone carver...yea you know the guy who makes tombstones ( there everywhere) they sand blast all the time and will ussually do them for next to nothing...since they arn't in the buisness....just ask them whne the next time they will be doing it or drop them off and have them give you a call when there done
