Old 09-30-2010, 04:45 PM   #1
bgsnake
bgsnake's Avatar
Cool 1962 project motor and tranny idea
hey guys.
my new project is a 62 with a 305 v6 5L. previous owner installed a new t5 tranny 5 speed. i am going to convert the truck from the torsion to a coil spring front end.
i need help knowing what motor and tranny combos fit best.
also, my 305 is in great shape, how much should i sell it for? along with the tranny? aftermarket a/c kit?
thanks for the input
bgsnake is offline   Reply With Quote
Old 09-30-2010, 05:59 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 1962 project motor and tranny idea
These links should help answer some of your questions:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 09-30-2010, 05:59 PM   #3
raycow
You will probably change the suspension crossmember, so almost any engine made by Chevy before the LS will be a bolt in, and mount adapters are available for the LS if you want one. Your T-5 will bolt up to a Chevy bellhousing. If you are wanting an automatic, it will be no more work to use a 200-4R or 700-R4 than something older.
Ray
raycow is offline   Reply With Quote
Old 10-02-2010, 02:02 AM   #4
bgsnake
bgsnake's Avatar
thanks for the good info
motor, swap, transmission
