Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 09-30-2010, 11:21 PM   #1
Berndtc426
Berndtc426's Avatar
72 GMC Duramax
I was looking around to see if I could find anyone who has put a duramax in there old GM truck. I like the idea of a diesel truck, and wanted to know how much work it is to make the swap. I've been told that it will cost around 10K.
Berndtc426 is offline   Reply With Quote
Old 10-01-2010, 11:56 AM   #2
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Re: 72 GMC Duramax
I'm thinking that Duramax will be more than 10 grand alone! Is that the banks twin turbo supercharged marine crate motor? I like!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 10-01-2010, 06:49 PM   #3
Berndtc426
Berndtc426's Avatar
Re: 72 GMC Duramax
It sure is. I was thinking about getting a donor truck from a scrap yard. People say I can pick one up for around 5,000 bucks
Old 10-01-2010, 07:00 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 GMC Duramax
I haven't done one but have been thinking real hard on a dmax car of some sort. I have heard that if you look in the right places, engines with trannys and pcm's, can be picked up for as little as $2500. Honestly I haven't been looking, because I need to finish some other projects. There is a member on this site whom is doing a 83 or 84 dmax chevy, and it is unbelievably nice! I'll see if I can fin it for you.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-01-2010, 07:23 PM   #5
Dieselwrencher
Re: 72 GMC Duramax
Ok, I was wrong. It is a 1982. Go check it out. Probably one of the nicest trucks on the board being assembled.
http://www.67-72chevytrucks.com/vboa...ghlight=diesel
Ryan
Old 10-02-2010, 12:08 AM   #6
shovelbill
Re: 72 GMC Duramax
wow.....what's the rest of the drivetrain that'll support all that torque? there's some serious talent on this board.
shovelbill is offline   Reply With Quote
Old 10-02-2010, 12:30 AM   #7
Dieselwrencher
Re: 72 GMC Duramax
I'm pretty sure he is using an allison transmission but I'm not for sure on the axles.
Ryan
Old 10-02-2010, 07:28 PM   #8
Berndtc426
Berndtc426's Avatar
Re: 72 GMC Duramax
If I can get all the stuff together I want to put an allison behind the muramax, not sure on the t-case, with a dodge dana 80 rear with disc brakes and a dana 60 front. At least thats what I'm thinking at this point.
Old 10-02-2010, 10:47 PM   #9
Lonnies Performance
Lonnies Performance's Avatar
Re: 72 GMC Duramax
There is a link to my build in my signature. It's an '82.
http://www.lonniesperformance.com/82chevyduramax.htm
You will sink an easy $6-8K in the engine/trans. If you want to build it up, add another $4-6K without even getting inside the engine.
Inside the engine you can sink an easy $10K
You can do the Dodge axles & transfer case with some modification.
or the Factory Dmax transfer case with a late 70's Ford front axle.
Either way, plan on lots of work.
Lonnie Pavtis
'82 Duramax Conversion in progress
Lonnies Performance is offline   Reply With Quote
Old 10-02-2010, 11:21 PM   #10
Berndtc426
Berndtc426's Avatar
Re: 72 GMC Duramax
Thanks for the info. Maybe it should be a project for down the road.
Old 10-04-2010, 03:06 PM   #11
Dieselwrencher
Re: 72 GMC Duramax
This past weekend I saw a LBZ duramax in a 66 chevy II Nova wagon with parallel turbos. It was pretty sweet!
Ryan
Old 10-07-2010, 08:06 PM   #12
K20-69-POS
Re: 72 GMC Duramax
http://www.truckinweb.com/features/0.../photo_01.html
theres a build thread of that truck somewhere on the web.
'69 K20 292 4spd 4x4 - project 27,000 orig. miles
'98 1500 suburban 4x4 - driver 219000 orig. miles
K20-69-POS is offline   Reply With Quote
Old 11-16-2010, 05:17 PM   #13
archie87
Re: 72 GMC Duramax
there is a guy in ok putting a dmax in a s10 I will try and get a link posted tomarrow for it
founnd it
http://www.s10forum.com/forum/f221/its-alive-340611/
archie87 is offline   Reply With Quote
Old 11-18-2010, 12:59 AM   #14
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: 72 GMC Duramax
here is something cool for ya:
http://67-72chevytrucks.com/vboard/s...t=duramax+swap
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-18-2010, 01:20 AM   #15
Musclerodz
Re: 72 GMC Duramax
that motor is about $30k+ you got pictured there. truck will be the cheap part
Mike Redpath
Musclerodz is offline   Reply With Quote
