10-07-2010, 07:08 PM | #1 |
cab paint divider trim
Anyone know the correct placement and spacing for the clips that holds this trim on. Any other tips would be greatly appreciated also for installing the clips and trim............beater
10-07-2010, 11:34 PM | #2 |
Re: cab paint divider trim
Here's a diagram. Reference point, circled 40, is 40" above bottom surface of the rocker panel (not the pinchweld flange) or a little less than the highest point of the outer roof panel. The side studs are measured from a straight edge along the rear panel.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
10-09-2010, 11:18 PM | #3 |
never added trim to that area, check out some pics and get the molding and hold it where it fits the best and then put some tape at the top and bottom of the trim then remove the trim and find the center of the two tape lines and that is your trim center line and, mount the pins on that line. hope this helps. cheers,Pat
10-10-2010, 01:09 PM | #4 |
also to install the pins you use a stud welder but if you do not have one they make the screw in type studs. You just drill a little hole and screw them in. We put some sealant on them to help stop any rust. They work fine
09-06-2013, 05:25 PM | #5 | |
and on the sides, is the bottom of the paint divider supposed to lineup with the bottom of the drip rail, or a little above it. Thanks in advance, Dont have a truck here that i can be 100% sure it is right to take measurements from. This cab i am installing the paint divider on is a 70. Thanks
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT "Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C. "1968" C10 Shortbed project |
