Old 10-11-2010, 05:18 PM   #1
Mikedub82
Mikedub82's Avatar
Zs'd frame
I am just about finished bagging the back of my 66 step side. I used a rear end from a 77c10 to go 5 lug. I am bagging the front and converting to disc at the same time. I was wondering how many inches I need to Z the frame to make it lay body, and should i remove the engine. Name:  5.jpg
Get Low
Mikedub82 is offline   Reply With Quote
Old 10-11-2010, 09:25 PM   #2
FnLow69
FnLow69's Avatar
Re: Zs'd frame
It depends on tire size, Removing the engine might make it easier but ive seen it done with it in place.
Justin
FnLow69 is offline   Reply With Quote
Old 10-11-2010, 09:29 PM   #3
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Re: Zs'd frame
Nice work bro! What brand/size stepnotch is that?
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 10-11-2010, 09:38 PM   #4
mongoose
mongoose's Avatar
Re: Zs'd frame
is one of the notches on backwards or is it supposed to be like that?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-11-2010, 11:17 PM   #5
stefan
New Member
Re: Zs'd frame
They both look right to me,i dont see either one backwards.great looking work,get more pics.
stefan is offline   Reply With Quote
Old 10-12-2010, 09:33 AM   #6
Mikedub82
Mikedub82's Avatar
Re: Zs'd frame
Its not backwards, I think they sent on odd peice with the notch kit. it was a little longer. Its been fixed since the pic was taken. i had to cut about an inch off the front and add about 1 1/2 inch to the rear to secure it to the frame. I am going to run 20's in the front maybe 22's in rear. I have 2 1/2 inch drop spindle for the front. I think I should only need about 3 inch z to get it there????
Get Low
Old 10-12-2010, 10:30 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Zs'd frame
I'm not a big fan of Z's, but everything I have read indicates a 3" is the best way to go. Anything more and the steering/motor/etc issues are compounded significantly.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-12-2010, 11:51 AM   #8
Mikedub82
Mikedub82's Avatar
Re: Zs'd frame
Thats what I have been reading, the 3 inch seems to come with alot less problems.
Get Low
Old 10-12-2010, 02:32 PM   #9
Mikedub82
Mikedub82's Avatar
Re: Zs'd frame
The notch came from *****************
Get Low
Old 10-17-2010, 11:10 PM   #10
superflysteiny
superflysteiny's Avatar
Re: Zs'd frame
No more than 3 inches if you z the frame
superflysteiny is offline   Reply With Quote
Old 10-17-2010, 11:11 PM   #11
superflysteiny
Re: Zs'd frame
Only issue is steering double u joint still very easy
