Sb 400 club
Autpometer gauge install... some info and a few questions
Okay I did this swap over the weekend. It is pretty easy and nothing to be afraid of. Just take your time and do things right.
First some questions... 1) I put these in a 1977 K10 with a th350 automatic and np205 transfer case. Does anyone have a part number to a speedo cable that will work for this application? 2) Before doing the swap my Water temp never got above 180 on the factory gauge. On the auto meter gauge it has read as high as 210 and normally goes down to 180. I have a 180 degree T stat in the truck. Is something wrong or is this a safe operating temp? Important notes: -Make sure that you use removable connectors or a bulk connector if you ever want to be able to remove the dash. -Be careful how you route the wires -A 73 to 1979 dash bezel is not the same as the 81 and up models. The 81 and up will not fit!!!!! right with the older style dash pad Okay and now the best info that will make your swap easier then mine was.. For all trucks there will be a bulk connector that is labeled with 18 ports. 73-76 used different color wires and different wire locations then 77 and up trucks. Since my truck was built in 77 it actually used a 1976 harness which there is no info on the internet about. 1973-1976,77 1. Light Green - High beam 2. Gray - Instrument cluster lights 3. Black - Ground 4. Pink - Power when ignition on 5. Pink - Power when ignition on 6. Tan/ White Stripe - Parking brake (jumper to 17) 7. Tan - Fuel sender (jumper to 18) 8. Dark Green - Water temp 9. Black - Ground 10. Light Blue - L turn signal 11. Dark Blue - R turn signal 12. Pink - Power when ignition on 13. Empty 14. Empty 15. Black - Ground 16. Pink W/ Stripe - brake warning light 17. Tan/ White Stripe - Parking brake (jumper to 6) 18. Tan - Fuel sender (jumper to 7) Keep in mind my truck does not have an electric choke nor does it have a "fasten seat belt light" It did have a separate 2 wire bulb for the "4wheel drive lock " light but since I installed a different transfer case and twin sticks this wire was disregarded. On 77 to 87 models: 1. Light Green - High beam 2. Gray - Instrument cluster lights 3. Black - Ground 4. Pink/ Black Stripe - Power when ignition on 5. Tan - Oil sending unit 6. Pink/ Black Stripe - Power when ignition on 7. Pink - Fuel sender (jumper to 18) 8. Black - Ground 9. Dark Green - Water temp 10. Black - Ground 11. Light Blue - L turn signal 12. Dark Blue - R turn signal 13. Empty 14. Yellow - Fasten seat belt 15. Medium Blue - Choke 16. Pink/ Black Stripe - Power when ignition on 17. Tan/ White Stripe - Parking brake 18. Pink - Fuel sender (jumper to 7) I did not have a dash harness out of a TBI truck (1987) so I do not know how that would vary if it all. Hope this helps! Other good sources: http://www.73-87.com/7387garage/inte...ge_surface.htm http://www.73-87.com/7387garage/inte...s_recessed.htm I used a smaller speedo and tach then most and mounted them to the factory brackets. This eliminates the angle issues others have by surface mounting but it does not look as clean. As mentioned above I have no finished pictures because I need to cut my stock dash bezel to fit the four 2 and 5/8 and install it. The 82 dash bezel i used would not mount to my older style dash pad. The 3 led's on the top are for (p brake, high beam, and brake pressure). For turn signals I went to radio shack and found some larger LED's that pushed securely into the arrows from the back side. ![]() ![]() The fuel gauge is pegged in both pictures because my sender got messed up offroading.
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 10-12-2010 at 06:38 PM. |
Badass
Re: Autpometer gauge install... some info and a few questions
the fuel gauge problem is it has a short some where in the system
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
Sb 400 club
In that case i need to trace some wires. Thanks for the tip. The gauge will read lower when gas level drops. thats why i thought the sender got messed up from all the bouncing and slams it has been through off road. then again it does have a ****ty splice down by the tank...
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 10-12-2010 at 08:40 PM. |
78K & 79C Jimmys
if the sending unit is shorted to ground it goes empty,no connection to sending unit does that
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
what if the unit reads almost half when the tank is full and goes down from there and sometimes spikes up like its working then goes back?
Sb 400 club
SO your saying it is a open sending wire? It is strange the tank always worked great until One offloading trip when it mysteriously stopped. The only wiring issue is one splice . Aside from that the only other option is the sender itself. Do i have this right? As can be seen the original gauge was reading way over full before I did the swap.
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
78K & 79C Jimmys
seems like open
in high school,everyone wanted a drive home,i had a switch under the dash that grounded out the sending unit(72 ventura) get a few bucks from the ppl go to get gas.click the switch after the car was off,pump get back in and you got gas. thats why i think it's open lol
#8 | |
Badass
![]() ![]() ![]() smart man
There is a wire from the sender to ground at the tank. If that connection is open you will get the 3 oclock reading.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck Last edited by MTCK; 10-13-2010 at 12:49 PM. |
