10-21-2010, 03:19 PM | #1 |
vent window delete?
I took upon myself the task of installing new vent window weatherstripping on the driver side door of my 1987 gmc last wednesday. It didnt go too well. the rod coming off the bottom of the glass frame broke so i spent time tacking it back on and lining it back up and repainting it. I purchased the 1 piece style weatherstripping (which my truck is supposed to have) and my truck had the 2 piece style. why does my 87 have the 2 piece style anyway? its supposed to be 1 piece according to anybody i talk to.
Also, the division bar weatherstrip piece that came off had little hooks on the back of it to go in the holes of the bar and i'm told all 2 piece models were riveted and need to be redone that way. anybody else have the hook style instead? nobody sells them that i found. I made the 1 piece fit but it still squeals and whistles like before anyway... i'm a little discouraged and wondering if i should go through that hassle again with the correct rubber and hopefully it will stop the noise or just go with the single window conversion instead. what do you guys think? success stories? |
10-21-2010, 03:23 PM | #2 | |
Re: vent window delete?
If you had trouble with the install of the gasket for the factory glass, don't expect the one peice glass to be any easier. In the beginning they had major issues with fitment and from what I here it has been revised and a little easier and better functionally, but I can't offer any personal experience with the kits.
Smoke Tires, not Drugs Last edited by MONTEZ; 10-21-2010 at 03:24 PM. |
10-21-2010, 05:16 PM | #3 | |
These trucks whistled and leaked when new. If you want it really quiet you should probably take a look at the one piece side glass. Even that might not do it, since wind noise was also a function of door fit, A pillar gap, etc. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 10-21-2010 at 05:17 PM. |
10-21-2010, 07:16 PM | #5 |
Garage wrench
I installed brand new GM vent window assemblies into my '85 Suburban and it's better than new. While I was at it, I installed new window weatherstripping aswell. No leaks at all, nice and quiet. Maybe that's an option for you. I found that replacing the entire vent window was easier than trying to replace just the window seals.
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
10-21-2010, 07:48 PM | #6 | |
Crew Cut
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
10-21-2010, 08:46 PM | #7 |
Do you guys know about what the new assemblies run?
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
10-21-2010, 08:50 PM | #8 |
78K & 79C Jimmys
i changed the front glass and vents/seals from my 89 burb to the 78 jimmy,the glass was way thinner but vent closes right and the 89 has locks on the vents
note the pass side of the 88 Texas burb has always been(still is)sealed closed,had to cut the drivers to open it,back doors had no motors/marks to show they ever did
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
10-23-2010, 02:45 AM | #9 | |
11-21-2010, 12:54 PM | #10 |
I have 2 87 models one gmc and one chevy both have the two piece seals.. like you I have ordered and received the 1 pc style. Bad thing is the seal that were there were fine just a little weathered in the chevy but since the truck is getting painted I removed all the old seals and now wondering what to do with the vent glasses.. wonder if gm still makes the orginal 2pc seals. the rear piece hooks in just as your were saying.
11-21-2010, 03:09 PM | #11 | |
Arrived on a Pale Horse
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
11-21-2010, 06:44 PM | #12 | |
Garage wrench
