Old 10-29-2010, 06:12 PM   #1
Hulk Will Smash
Hulk Will Smash's Avatar
Hydroboost question
Quick question about the hose that goes between the bottom of the remote fluid resivior and the top of the PS/Hydroboost pump (on the front of the motor)...
Does anyone know whether that's a fitted (i.e. molded) hose (as it appears it should be due to the angles of the bends) with a part number, or not?
Thanks.
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 10-30-2010, 07:38 PM   #2
USSkoval
Re: Hydroboost question
Yes, it's a molded hose. I don't have a part number though.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 10-30-2010, 08:33 PM   #3
irishman999
irishman999's Avatar
If you have a local hydrolic supply or fitting shop usually they can make you a replacement hose quick and for a decent price. No need for ordering one.
irishman999 is offline   Reply With Quote
Old 11-02-2010, 06:01 PM   #4
Hulk Will Smash
Thanks guys, I figured it was molded due to the angles. Local parts places don't have a pn either. Guess I'm going to have to spend some QT on the racks or just pick up some aluminum elbows and make something.
Irish, I'm talking about the rubber hose between the pump and the resivoir not the lines from the pump to the steering box/brake booster. It's just push on rubber hose.
Old 11-02-2010, 10:00 PM   #5
USSkoval
A lot of full size vans and Astro vans have the remote reservoir, one of them might work well if you cut it down to size.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 11-04-2010, 12:54 AM   #6
Hulk Will Smash
Thanks man. My neigbor's actually parting an Astro this weekend. I'll give it a peek.
