11-03-2010, 01:57 PM | #1 |
oil gauge pegging out
pardon my ignorance, but on my 82 cluster i have the oil gauge that goes from 0 to 60. is it normal for that thing to be pegged out on 60 at all times? and what exactly does the 0-60 represent?
11-03-2010, 02:31 PM | #2 |
Re: oil gauge pegging out
I have an 87 and the oil pressure gauge stays at 60, it will move slightly back off the peg and back again while the engine is running. It runs great, I think its just something the stock gauge does after awhile on these older trucks. Sorry though, I don't know the more technical reason why it does this.
11-03-2010, 03:43 PM | #3 |
Cruzzzn' Vet
Mine will peg out when first starting up and then settle down to 40 psi
11-03-2010, 03:47 PM | #4 |
PSI = Pounds per Square Inch
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
11-03-2010, 04:06 PM | #5 |
If the gauge pegs with "ignition on and engine off" either the sending unit is bad or you have an open wire to the sending unit. Hard to see on some engines, behind the distributor. If it pegs while engine is running, check the oil pressure with a hand held gauge. If oil pressure is normal most likely the sending unit bad. Hope this helps.
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
11-03-2010, 04:19 PM | #6 |
i'll have to look at it and see what happens. i rarely pay attention to it bu i don't think its ever left 60. of course i don't normally drive it more then 15 minutes at a time so who knows.
