Old 11-04-2010, 12:09 PM   #1
cochino12
It followed me home?
cochino12's Avatar
burb buckets & middle seat to crew cab
So I pulled some really nice burb buckets from the junk yard today and was curious how much work it is to put them in my crew cab. I did pull the front mounting tabs but I am more curious about the rear of the front seats and also If I can pull the middle seat from the burb and use it as my back seat in the crew cab?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-04-2010, 12:29 PM   #2
63chevyll
gets board easy.......
63chevyll's Avatar
Re: burb buckets & middle seat to crew cab
what year burban buckets?
63chevyll is offline   Reply With Quote
Old 11-04-2010, 02:45 PM   #3
Jonboy
Slots go on anything!
I don't think the second seat will work. IIRC, the rear seat on a CC is similar to the floor of a pickup to clear the fuel tanks, so the burb seat would ride a lot higher. I think.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-04-2010, 03:06 PM   #4
cochino12
cochino12's Avatar
88
That makes sense oh well. Any idea about the rear bracket of the front seat?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 11-04-2010, 04:02 PM   #5
Jonboy
If you got the extra stand, I think all you have to do is drill out the rear inner hole and reinforce it. I have heard you may have to bend the rear of the slider fo fit the floorpan in a regular cab, but you may be OK in a crew cab. I would just use a nut and a large fender washer for the rear inside hole.
