11-16-2010, 12:24 AM | #1 |
Cutting A/C Vent Holes in Dash
Anyone have advice on how to cut out the holes in the dash for the A/C diverter balls for a non a/c dash? (Cutting only once is kind of important here)
11-16-2010, 01:26 AM | #2 |
RAT1968 '68 Cab/'71 Parts
Re: Cutting A/C Vent Holes in Dash
Hole saw. 2 1/2" for Vintage Air.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
11-16-2010, 01:35 AM | #3 |
My 69 was a non a/c truck, I put vintage air in the truck, but did not like the cheesy vintage air vents that came with my gen2 kit. I went to a salvage and found a 72 that had factory air, Traced the factory holes with a piece of paper and pen, taped them to my freshly painted dash and very carefully cut them out with a mini air saw.
Im pretty sure you can see a pic of them in my build thread.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner Last edited by gearys 5600; 11-16-2010 at 01:36 AM. |
11-16-2010, 02:08 AM | #4 |
magwa - did you use factory vent balls or vintage? Did you cut into the slanted part of the dash at all?
geary - what was cheesey about the vintage vents? I'm starting to think that that would be the easier route, although I already have the factory vents to install. |
11-16-2010, 02:15 AM | #5 |
I just didnt like them.They look and feel cheap. Now several of the aftermarket a/c manufacturers including vintage, make nice vents that you can buy, they are usually pricey.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629 1969 custom/10 swb--SOLD 1968 swb 50th anniv.--SOLD 1967 camaro ss/rs..LS-6-speed, 16-year long project 1956 chevy nomad 1955 chevy 210 2-dr sedan 1978 el-camino ss 1-owner |
11-16-2010, 02:25 AM | #6 | |
vent mounts at the screw holes on originals. As for the VA, the fit is just a hole. And then and come in from the back of the dash with the threaded "collar" to pick up the threads on the vent that you push thru from the front. I used the VA template that's in the kit for placement at first. Then, I decided to look and feel around the back for the spot that was the most flat but had the most clearance. Basically, it was logical. And, even for me, a no-brainer. However, I DID learn from the last time I made this cut in a non-air dash to take it easy with the hole saw...use a sharp one, a good drill bit. And, I opted for higher drill speed and lower pressure on the drill. Last time I did this, the hole saw jumped out of the groove it was cutting and left a little gouge in the dash I had to look at for a while. This time...slower and smart(er).
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 11-16-2010 at 02:28 AM. |
11-16-2010, 08:33 AM | #7 |
I am installing a Oldair unit in my non air truck right now and it came with smaller than factory ball vents.I had to use a 2 1/4" holesaw and it worked out well after i called Oldair to find out how to secure them.I like this unit but the instructions are not in depth enough.
11-16-2010, 08:46 AM | #8 |
I did this in the last year. I used a hole saw for the diverter balls. I'd have to confirm this but I believe I used a 3" saw. The center vent I cut with a dremmel tool.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-30-2017, 10:08 PM | #9 |
will the center vent fit in the ash trash opening???
07-30-2017, 11:48 PM | #10 |
Steven,
The ash trash is only for trash from ashes. I guess you can make *anything* fit *anything*. But I'd venture that you're better off cutting the center vent hole where it belongs..... Then again, if it's about custom, there are some very talented metal magicians reading this that would likely say different... I use Vintage Air vents in a non-air cab. Never failed,,,,when I went slowly and used the correct tool for the job. .
07-31-2017, 06:21 AM | #11 |
Old member
I cut the factory vents in mine. I used hole saw and snips and small grinder.
07-31-2017, 08:56 AM | #12 | |
wow!!! you inside looks very nice and clean!!
thank you for the reply. i don't smoke and can't imagine anybody smoking in these pickups or any car/truck for that matter thank you again for the pictures. i was curious of the placement of the "ball vents" Quote:
07-31-2017, 11:17 AM | #13 | |
I don't smoke either. And no one smokes in my truck (or my car). But, like I told the guy in the office next to me some years ago, after I followed him home, each of us driving our own car (he just bought a new Jag): "Jim, America's a great place. A place where a guy that has the dough can buy a fancy car, and no one can stop him from f*#king it up by smoking in it the first two minutes off of the showroom floor". I meant it. His car, his money, his lungs. Dremel, grinder, drill, and hole saw. Not in that order. No coffee. No beer....You'll be good.
07-31-2017, 12:21 PM | #14 | |
i was thinking dremel also. this will be the first add-on once i get my little guy going. is that your stereo, with the screen? |
07-31-2017, 12:32 PM | #15 | |
Silly overkill: GPS, Sat Radio, DVD, and 10GB music loads. I usually know where I am, and prefer to listen to the motor over music. But my pal gave me this nice set up out of a car I sold him. All I had to do is make the box and put some of the extra "kicker" carpet on it, buy a couple of speakers, and install the damn thing. I had nothing else to do when he dropped it off, so I went to town. Nice spring day, windows open? Beats listening to canned music. Rather hear the rumble. But, what the heck? Every once and a while. Although, I dumped the $at radio subscription.....
07-31-2017, 12:53 PM | #16 |
haha
NICE!!! |
07-31-2017, 01:17 PM | #17 |
Yes, 3" is the size hole saw to use with a 12" long pilot rod.
I had old left and right vent bezels laying around so I ground off the portion that fits into the hole in the dash. Then I placed the bezels on the dash and traced the outline onto the dash. That gave me a place to start to center the hole. Once I was happy with the center it was a matter of drilling the pilot hole and getting after it. It is not easy as the hole saw will bite the inner portion of the hole first. It takes patience and strength to keep the hole saw straight. I did chew up the left hole a little bit, and my body guy had to fill some metal back in but I very happy with the result. Also, I did not notch the top of the hole as the originals have, and I just drilled a small hole for the bezel mounting screw. |
07-31-2017, 02:57 PM | #18 | |
What color is that truck? I like it. |
07-31-2017, 04:58 PM | #19 |
Don't want to hijack the thread, but it is PPG Custom Kindig It Cool Clay, two tone with Toyota Arctic White top.
07-31-2017, 05:48 PM | #20 |
I used stock vents too. I traced a real a/c truck dash and went to town. It was hard but the end result was nice. Dremel for the center.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
07-31-2017, 11:02 PM | #21 |
Used a 3" hole saw also- went slow- turned out nice
08-01-2017, 07:35 PM | #22 |
I made a template from an AC truck then traced to my dash and used a reciprocating body saw. Done in 5 minutes and very easy to control.
1968 C10 292/3 spd - sold 1969 K10 350/3 spd/205 - sold 1971 K5 350/4 spd/ 205 - sold 1970 K20 350/350/205 - sold 1969 K20 396/400/205 - work in process |
