Old 03-04-2003, 12:45 AM   #1
matt67350
matt67350's Avatar
u-bolts rear axel?
Best way to remove the u-bolts without a tourch?
There really rusty and dont want to move.
Any ideas or tools to use or thing you have done would help.
Thanks Matthew
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 03-04-2003, 01:10 AM   #2
dmurphy68
one thing comes to mind PB BLASTER it will loosen any rusty bolt
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 03-04-2003, 01:12 AM   #3
Project1970
14.1 @ 96MPH
Project1970's Avatar
Torch 'em. When I tried to get mine off, I think all but one broke...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-04-2003, 01:53 AM   #4
moose
For the bolts heat them up and then use a big cheater bar. To get then lose from trailing arms BFH and a large pry bar worked for me good luck. Moose
69 C/10 swb coming along slow but sure 4 yr and counting Omaha Nebr
7I JIMMY 350 4speed daily driver/next prodject
99Yukon wifes
moose is offline   Reply With Quote
Old 03-04-2003, 02:08 AM   #5
casey
casey's Avatar
hacksaw and use new ones there not worth saving
casey is offline   Reply With Quote
Old 03-04-2003, 03:02 AM   #6
hobby67stepside
Do you mean you don't have access to a torch or you don't want to use one. If you don't have access rent, borrow, beg, buy, whatever, but you will save tons of work and trouble if you use heat.
hobby67stepside is offline   Reply With Quote
Old 03-04-2003, 03:11 AM   #7
Alexis
Member since 2000
Alexis's Avatar
cut them off with a die grinder......
Alexis is offline   Reply With Quote
Old 03-04-2003, 05:56 PM   #8
Earl Junior
Cadillac power
Earl Junior's Avatar
Stick a socket on them and tighten them until they snap. They are a cheap part and not worth saving.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 03-04-2003, 06:41 PM   #9
matt67350
matt67350's Avatar
If I destroy them, then where do I get replacements
Old 03-04-2003, 06:45 PM   #10
dmurphy68
any parts store has replacements or if you are lowering your truck most kits come with them
- George Washington
- Thomas Jefferson
Later Darren
Old 03-04-2003, 06:50 PM   #11
Huck
Huck's Avatar
I worked on mine for hours, tried penetrating oil, heat, etc. Finally did get them off only to find that they were badly rusted and not worth saving. Went to an auto/truck spring shop and paid like $6.30 each for new U bolts with the washers and nuts. Next time I will cut them off with a torch, hacksaw, or grinder!!!!!
Huck is offline   Reply With Quote
Old 03-05-2003, 02:45 PM   #12
matt67350
matt67350's Avatar
OK, guys thanks for all the help. This is what I did,
used a 41/2 grinder to start a cut and then finished with a cutoff wheel on a die grinder. Had to make to cuts on both to get the u- part out of the way, then used the BFH to drive the rest out the bottom of the trailing arm. Found new u-bolts here local for $26.00 pr. Thanks for all the help guys .
