Old 11-18-2010, 06:06 PM   #1
hotrodsuburban
Exclamation wiper motor
I need to replace my wiper motor, but I cannot figure out how to get the vent cowl off. I have a '90 'burban. Any help is appreciated.
hotrodsuburban is offline   Reply With Quote
Old 11-18-2010, 07:10 PM   #2
HOGDADDY
HOGDADDY's Avatar
Re: wiper motor
It had 4 bolts on front and in back it has 5 nipples that push into holes in rear cowl if it is same as 86 truck.
HOGDADDY is offline   Reply With Quote
Old 11-20-2010, 12:10 AM   #3
hotrodsuburban
Thumbs up Re: wiper motor
Thanks, that is what I was thinking. I was tring to keep from breaking something.
Old 11-22-2010, 09:11 AM   #4
Frozen1010
Frozen1010's Avatar
Re: wiper motor
I also have a 90 suburban, but you can replace the wiper motor with out removing the cowl. I know because I just removed one from a 89 out in the junk yard with out taking the cowl off.
Frozen1010 is offline   Reply With Quote
Old 11-22-2010, 11:04 PM   #5
SBTork
Garage wrench
SBTork's Avatar
Re: wiper motor
yes, you should not have to remove anything other than the wiper linkage/transmission that connects to the motor. I've done this several times, just use the access hole above the motor on the cowl.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-23-2010, 12:51 AM   #6
hotrodsuburban
Re: wiper motor
Thanks guys, I was just going by what the Chilton's said.
Old 11-26-2010, 02:19 PM   #7
hotrodsuburban
Talking Re: wiper motor
It's all done, thanks for all the help.
cowling, wiper motor
