Old 11-19-2010, 03:23 AM   #1
RED-85-Z51
My "new" 86 K2500 has suffered a near disaster.
The 86 K2500 I bought last week, I bought it knowing it had a dead miss...but it ran and the guy drove it to my house, but it ran like crap.
So I started to investigate, the other day. found that #3 plug was always soaked and never got warm when the engine ran, and I was getting tons of reverb out the carb hen I brought it off idle.
So I pulled the valve cover and found a surprise...The #3 intake spring had shattered and 2 full turns were sitting on top of the head. Looks like they drove it this way for a very long time, somehow.
Obviously, Im pulling the heads off now, for more reasons that one. The intake is packed with carbon, thick oily deposits...this will be replaced with an edelbrock performer RPM aluminum intake. The Q-jet was also heavily deposited, it's varnished, and the secodnary pull off thing is messed up..Im seriously thinking about just putting on a Holley 4V...and just going that way, but its undecided as of now.
I detect damage to the #3 intake lifter and Im about positive I feel some damage to the lobe...and I convieniently have a new in box Lunati VooDoo 60101LK sitting next to me...so Im gonna slide in a new bumpstick.
Also replacing the timing set...I dont like the plastic gear..
The heads are going to the machine shop, new valves as needed, shave as needed, redo all valves and guides, install new guide seals, and install new valve springs. Ive got a set of roller tipped 1.6 rockers coming for it.
The exhaust is shot to hell, Im doing the 290 dollar full exhaust from summit with LT headers.
Im deleting all the emissions crap..not a single peice is intact as it is.
Replacing every inch of vac line, and plugging the "ported vacuum" ports.
new water pump and timing cover, new valve covers
Edelbrock 14" air filter
Should run well. What's troubling is I removed the carb this morning and there is no kickdown cable for the TH350 some genius transplanted in this tthing...
Also, some genius ran a vac line from the manifold to the EGR valve...effectively pinning it wide open.
All new head bolts, valve cover bolts, breather setup, and intake hardware...
I should have some pics of the engine progress tomorrow...
RED-85-Z51 is offline   Reply With Quote
Old 11-19-2010, 09:50 AM   #2
Davidmichael
Davidmichael's Avatar
Re: My "new" 86 K2500 has suffered a near disaster.
wow hope you got it cheap or the body is mint.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-19-2010, 11:28 AM   #3
RED-85-Z51
not really..he was firm on 700 cash...
Old 11-19-2010, 09:38 PM   #4
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
$700??? That sounds like a good deal to me, broken motor and all.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-19-2010, 10:07 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
x2 atleast for my area....
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-20-2010, 02:42 PM   #6
RED-85-Z51
Got the head off. one piston is beat up, alot of cylinder wear on 2 cylinders, likely due to the incomplete combustion from damaged plug wires (fuel washed the oil off the cylinders)...
So next weekend the engine is coming out...Ill have it punched 60 over. New rotating assembly/have the crank turned. New main and rod bearings, seals, etc..
Really didnt want to have to do this...but oh well, will be a better truck as a result.
Old 11-20-2010, 05:33 PM   #7
Davidmichael
700 is not all that bad. said and done it will still be a good truck.
01 S10 ZR2
Old 11-20-2010, 11:31 PM   #8
RED-85-Z51
Ill be pulling the engine next weekend, at which time Ill be able to accurately confirm it is indeed a 350 and not a 305, and rather or not it is a 1pc rear main or a 2pc.
At which time Ill be able to order the 383 Stroker kit for it...
http://www.jegs.com/i/Eagle/356/B134...oductId=763943
Old 11-21-2010, 01:07 AM   #9
Jonboy
Slots go on anything!
If you have the head off, it's easy to confirm engine size. A 350 has a 4" bore, and teh 305 is substantially smaller (don't remember the size exactly, but a good bit smaller). They share the 3.48" stroke.
1974 Jimmy- 5.3/4L80e/NP241
