11-23-2010, 11:09 PM | #1 |
Camaro front end
Is there any links to info on how to do this? I am starting research on fixing up my 57 gmc and would like to do this. Is there any threads that do a good job demonstrating the process? What are the key words?
11-24-2010, 12:55 AM | #2 |
Re: Camaro front end
here is a video how to do it http://nolimit.net/prodinfo.asp?number=D-101. I bought it an it was total worth it. i have not started the swap yet but it is clear and i don't think i'll have any problems.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
11-24-2010, 06:16 PM | #3 |
This thread started by Lux Blue on the HAMB is what a lot of guys internet wide are using as a reference right now and it is easy to follow. http://www.jalopyjournal.com/forum/s...d.php?t=148978 It pretty well walks you through the whole process on a chassis similar to yours.
11-24-2010, 08:50 PM | #4 |
This is what a friend of mine did to his 57,I'm going to redo my 53 just like it as I did it the first time like the Nolimit and this looks safer in my opinion
11-25-2010, 05:03 AM | #5 |
Hi Guys, I'm also grafting a camaro clip on my 56 GMC, after buying the no limit DVD & reading all the posts & builds I could find, I decided to go the Lux blue (hamb) way & slide it underneath, mainly because it looks easier for my capabilities.
Anyway I stripped the front off yesterday only to find that the GMC has a different radiator support & mounting location. It has a cradle around the radiator & mounts in the forward center of the front crossmember, not on top of the frame rails like the chevy does. That has kinda thrown a spanner in the works because I had it all planed out & I dont have any info on how it can be mounted on the camaro subframe? I hope I havent hijacked this thread but I thought any info would be relevant to the OP seeing he also has a GMC. ps Indian 113, your buddys frame you have posted looks awesome, I hope when I'm done mine will look as good! Last edited by Red Foreman; 11-25-2010 at 05:04 AM. |
11-25-2010, 11:56 AM | #6 |
Indian = Man that looks sweet looks 100 times better and simplier than the other ways I have seen done.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
11-25-2010, 01:16 PM | #7 | |
Semper Fi! |
11-25-2010, 04:59 PM | #8 |
Thanks Kaycee,after seeeing Rich's 57 my cut and but just didn't look right. The way he did it just looks so clean
11-27-2010, 02:17 AM | #9 | |
11-27-2010, 12:32 PM | #10 |
Just did this a few months ago. Its really easy, just measure a million times and cut once. The laying of the subframe under the truck frame is by far the recommended way for people who don't attempt fab work often. Doesn't look the best but I plan on boxing it in and dressing it up to look better. Plus if you plan on laying frame it gives you something to drag instead of your truck cab. With that said you can't even see it unless you plan on putting mirrors under your truck LOL.
11-27-2010, 02:06 PM | #11 |
mine is a little different but worked out great on my truck. and personally i think it looks cleaner.
'55 Chevy PU 2nd Series '97 Chevy Silverado XCab '13 GMC Sierra |
12-02-2010, 11:34 PM | #12 |
Well I have to admit I like em both, Sal did you tuck yours into the frame?
12-03-2010, 02:27 AM | #13 |
i guess you can say i did but are main goal was to look like the frame was made like this in 1955 if you know what i mean to we just shape the camaro clip back into the 55 frame giving me a real slick frame and then builky crossmember.
12-03-2010, 07:35 PM | #14 |
One of my running buddies has done a number of the Camaro/Firebird subframe swaps quite similar to Indian113 on 55/59 trucks and the guys who have them are pretty happy with them. They may not have the glamor of some front suspension setups but are solid and reliable when set up that way.
12-03-2010, 07:49 PM | #15 |
A friend of mine in town here did one and he cut the frame out and mounted the subframe level with bottom of the frame. It is on a 50 AD,loooks like it will be really low.If Ican get a chance I'll try to take a picture of it.
12-04-2010, 02:01 PM | #16 |
I did mine like in the pics. Took me a weekend to finish it by myself. Plus this way it gives it a small z so it sits a little lower.
12-04-2010, 04:12 PM | #17 |
12-06-2010, 10:46 AM | #18 |
I did mine like in Indians pics
12-08-2010, 04:32 PM | #19 |
jjjmm56, did you keep yours at original wheelbase or did it need extending to center the wheels?
12-31-2010, 01:28 AM | #20 |
please tell me what yr of vehicle did the sub frame come from, i have a 52 pickup and i have a 86 camero subframe but not sure if it will work
12-31-2010, 02:21 AM | #21 | |
You might be ok with 1st gen or late 60 early 70s nova. |
12-31-2010, 02:24 AM | #22 |
thanks red foreman )
12-31-2010, 10:00 AM | #23 |
12-31-2010, 12:16 PM | #24 |
Just an FYI there are 2 camaro sub frames listed today on caigslist
There are several 47-59 trucks/ parts listed the last few weeks. http://columbiamo.craigslist.org/pts/2136839939.html http://columbiamo.craigslist.org/pts/2135425858.html
http://67-72chevytrucks.com/vboard/s...d.php?t=413926 http://youtu.be/Qe9xJUhWkWc |
01-02-2011, 11:32 AM | #25 |
Here is what I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=414564 looks like Sal did the same.I been working on the 4 link setup inthe rear,but need to finish up on my core support and bumper brackets.Sal I like how your came out,can you post some more pictures and and info ? |
