11-25-2010, 12:08 PM | #1 |
any cool REAR VIEW mirrors?
hey im looking for a new rear view mirror, the one i want is $80 and im not redy for that yet.. so anyone have a cool on or idea they want to show off?
thanks |
12-12-2010, 12:19 PM | #2 |
Re: any cool REAR VIEW mirrors?
any ideas?
12-12-2010, 07:40 PM | #3 |
Old member
I don't know about cool factor but it tells you how cool it is outside now.
12-12-2010, 07:47 PM | #4 |
Can i ask how you did that and installed it? Thats awesome!
1969 Chevy c20(Miss Hackjob) |
12-12-2010, 08:17 PM | #5 |
also interested in that install
DJ |
12-12-2010, 10:55 PM | #6 | |
i guess i make number 3 that want to see how that was installed.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains Quote:
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there |
12-12-2010, 11:25 PM | #7 |
put me in line for the install instructions
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
12-12-2010, 11:48 PM | #8 |
Grandpa in the rustmobile...
interested also!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-13-2010, 12:18 AM | #9 |
yes, i do
i think that almost everyone here wants to know, including me!
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
12-13-2010, 01:38 AM | #10 |
Future TOTM Winner
I don't want to know, don't show me.
Just kidding, I want to also!!!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-13-2010, 02:02 AM | #11 |
Couldn't you just run the power wire inside the windshield gasket down to the drivers side bottom corner and through the drain hole to the fuse block?
12-13-2010, 02:07 AM | #12 |
Big Red - Now its a SWB!
yep, but what about the thermometer sensor, where does that install? I have the same mirror in my 01 tahoe and I always wonder where the sensor is.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
12-13-2010, 02:46 AM | #13 |
Legit. I wanna know how as well.
12-13-2010, 03:22 AM | #14 | |
I'm going to have to get one! Posted via Mobile Device |
12-13-2010, 03:23 AM | #15 | |
I'm going to have to get one! Posted via Mobile Device Posted via Mobile Device |
12-13-2010, 05:00 AM | #16 |
Always wrenching!!
I have the same mirror but only hooked up the lights.
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
12-13-2010, 10:28 AM | #17 |
I have one too. It is glued to the windshild like 71 - 72. I have a 70 so I used the mounting hole from the old mirror in the roof to run the wires. The outside temp sensor is mounted behind the front bomper. It also has 2 map lights, a compass and is auto dimming. You can also get it with home link. Great mod.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
12-13-2010, 11:33 AM | #18 |
More Cowbell....
I have the same mirror in my '69. I drilled a 1/4" hole right above the mirror (used rubber grommet) and also drilled a hole as close to the pillar on the driver's side as I could and fished my wires thru the roof. Then drilled a hole in the pillar to fish the wire down. Finally I drilled a hole behind the dash (removed cluster for ease of access) and fished it out.
Temp sensor is behind the grill (in front of the radiator). CLICK HERE FOR IMAGE
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket Last edited by Putter; 12-13-2010 at 11:39 AM. |
12-13-2010, 11:39 AM | #19 |
If I pull one of those mirrors from the Pic-A-Part can I get all of the wires?
12-13-2010, 11:42 AM | #20 |
More Cowbell....
Yes. They are just laying across the headliner. Clip as much as you can get to work with.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
12-13-2010, 12:47 PM | #21 | |
12-13-2010, 12:49 PM | #22 |
I have this one in mine. A little pricey, but looks very cool and dims those annoying rear view lights.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=79 Last edited by tdp67; 12-13-2010 at 12:51 PM. |
12-13-2010, 03:31 PM | #23 |
yes, i do
Hey andy i love how there is a 70 in the reflection of your mirror
12-13-2010, 05:36 PM | #24 |
Old member
Guy's it very simple really. I bought the mirror and senor off E-bay. The guy I bought it from had the wires figured out for me. The senor is mounted in the front on the Hood release so it get's clean air it's in front of the radator. I ran some small flat wire I bought at Radio Shack to the mirror under the rubber gasket. A hot wire for the compass, a ground and I think a senor wire maybe two senor wires. That's it.
You can see the wires here going into the gasket. I ran them down the drivers side and they come out right at the dash. Senor is the blue color thing. Mine does tell you when it is below 32 degree's outside no inside though. It will display ICE instead of temp. Mine has no lights. Yep it was Longhorn behind me headed to NC for the truck meet in 2009.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 12-13-2010 at 05:48 PM. |
12-13-2010, 07:59 PM | #25 | |
so how did you get the piece you glued onto the windshield off the car/truck you got your mirror from??
