determing lift size
I was wondering if someone with either a 4 or 6" lift would mind measuring the distance from the center hub to fender. I have a 1986 k10 wrangler that I just bought and is lifted but the previous owner wasn't sure of the size. I measured 26.5" on my truck from the front hub to the fender. Thanks in advance
Chris
Re: determing lift size
what size tires and measure from the ground to the bottom of the bumper.
We don't have our truck anymore but had an 86 with a 4 inch lift and 33's and I remember the bumper heights. Also look in the back, see if it has a block under the springs, if so how big is that block? Now they do have spring lifts instead of blocks and some kits are block and add a leaf, so maybe count the leafs of see if the big thick one is on the bottom it's short and thick, I aint sure if add a leafs go over that one or under it, I'd guess over it. But the rear should have a 4 inch or 6 inch block, maybe a 4 inch with add a leaf to make it six. So check both bumpers from ground to bottom and what type are they stock?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 Last edited by benoit454; 11-27-2010 at 04:42 PM. |
it has a 4" block in the back and looks like an add a leaf spring....front is a 5 spring pack.... wheels are 235/75/15 which is around 30"....I'll have to go and measure the bumpers to the ground
