Old 11-27-2010, 08:57 PM   #1
UNT8MDGT
UNT8MDGT's Avatar
Tire advice
Hey guys i just picked up a 1980 GMC 3/4ton long box and it needs a full resto. Im planning to run a 6" rough country lift and a 2" inch body lift.
The truck will see some towing duties,mudding and some HWY.
I want to run about a 38x??? any suggestion on what tire i should run?
smaller budget as well so something that will be affordable and that will last.
Thanks in advance guys
UNT8MDGT is offline   Reply With Quote
Old 12-09-2010, 12:19 AM   #2
83chev350
Re: Tire advice
well with 4'' susp and 3 body 35s with room so id say 38s no problem bigger u might have to cut wheel wells and use flairs
83chev350 is offline   Reply With Quote
Old 12-09-2010, 10:51 AM   #3
Burt4x4
Burt4x4's Avatar
Re: Tire advice
38 will be pushing the limits of your frontend but doable. With towing and some Hwy use I would get a radial like Swamper SSR, good in the mud and good wear for a Swamper too..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-11-2010, 08:50 PM   #4
Zane M
Re: Tire advice
I have no technical advice, but it seems 38s and budget are mutually exclusive terms.
Zane M is offline   Reply With Quote
Old 12-11-2010, 09:25 PM   #5
Altec
Getcha Pull
Altec's Avatar
Re: Tire advice
Your best bet would be like humvee take-offs. They are 12-ply radials. Wear like iron, and are some of the best all-terrain tires you can get in the ply range. And the extra plys really bump up the load rating, and the strong walls make sure they don't "walk" going down the road.
They are 37-12.5-16.5. They measure a true 36" tire. I'd do that, with a shackle flip in the real with 4" lift springs (Roughly 8" of lift total), and a 52" conversion in the front with 4" lift springs (Also roughly 8").
But you really don't need that much lift. I run 35" tires with 4" of lift. 6" will be fine with that.
like Burt said, large tires, and 10-Bolt/Dana 44's don't hold up well with large tires. Even 35" tires can bust them if you get bound up right. 38" tires is asking for trouble.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 12-17-2010, 11:29 PM   #6
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Tire advice
Yeah, I was gonna say towing with 38s? The sidewalls on those bigger tires are really soft. I had a 2 inch thorn puncture the sidewall of my 36" radial super swamper and I was really amazed that it went in so easily. Just the weight and rotating mass of those big tires alone would really be taxing the front 1/2 ton axle. I'd imagine the truck would get pretty squirrely with all that sidewall, too.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-18-2010, 10:28 PM   #7
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Tire advice
With that much lift you will need to put cross-over steering onto the list of things you will need.
Your best bet is to stick with a 4 inch lift if you want to do any towing, and I recommend 37" hummer tires also.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-18-2010, 11:24 PM   #8
rcflyer1234
rcflyer1234's Avatar
Re: Tire advice
Id say Pit Bull Maddog Radials would be good. Their aggressive but not too aggressive. They also have a 10 ply rating
http://www.pitbulltires.com/maddog_radials.php
rcflyer1234 is offline   Reply With Quote
Old 12-19-2010, 07:12 PM   #9
67chevy77
67chevy77's Avatar
Re: Tire advice
I run 40s with 9 inches and my buddy was running 40s with 8 inches and we both cleared them fine. So you shouldnt have problems fitting 38s.
Justin
1977 chevrolet rebuilt 350 9 inches of lift with 40s 4.56 gears. Work in progress.
1967 4x4 -sold-
1988 reg cab short bed 4x4 -sold-
1999 GMC extended cab short bed new body style Lifted on 33s.
67chevy77 is offline   Reply With Quote
Old 12-21-2010, 01:50 PM   #10
Mxracer202
Mxracer202's Avatar
Re: Tire advice
I really like the wrangler MTR's they look good and perform great, im not to sure how spendy they are though
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 12-22-2010, 02:33 AM   #11
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Tire advice
I have 40" gumbo monster mudders (about 38") with 4" suspension and 3" body but im about to remove the pos body lift, just the front fenders are trimmed a little.
Edit: This is on by blazer btw.
Tony
Old 12-22-2010, 04:01 AM   #12
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Tire advice
I ran 38's i downgraded to 36.5's.
The 38's with 4.56 gears were allright but i just destroyed way too much crap with them.
i went down to 36's for overall driveability and well i just got tired of climbing up there.
I origionally had 38/ 15.50 r15's from mickey thompson. wear patterns were great and road noise was manageable.
I Now swear by my procomp's! (x mud terrains)the road noise is minimal and the sidewalls are harder. ive had an entire bed of chopped mesquite and barley any sidewall bursting.
To me the procomps also have better channeling cut into them for mud and anythin sloshy. The mickey thompsons had better cold grip in the snow (still soft under pricking of a nail) and were more capable on sharp rocks.
if you want to see clearances issues check my build thread. i destroyed my front fenders with the 36.5s on a mud run. (i flexed they got stuck and curled my fenders in)
the 38's were worse. with a sky jacker 8in lift and a wedge block in there i couldnt articulate nearly as much as i wanted to due to tire rubbing. couldnt turn well either due to fender rubbing.
if you plan on running a10 in lift you will be ok.
BUT an important thing to remeber is CROSSOVER STEERING. You hit a bump with these tires you will know and it will be hard to manage.
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 12-22-2010, 04:03 AM   #13
dammitmitchell
the pollock
Re: Tire advice
p.s. any tire above a 35 is hell on a corp 10 bolt. you need to be running a 14bolt or more especially towing. i shattered my first corp 10 within two weeks of doing the lift. ring gear just could not handle the torque.
Army vet 02-08
Old 12-23-2010, 08:20 PM   #14
USSkoval
Re: Tire advice
Since you are on a budget and you plan to use your truck as a truck, skip the crappy body lift and go with a good 35 inch radial MT type tire.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Thread Tools
Display Modes
