front of transfercase leaking after frontend replacement
ok so i just got done swapping a front end in my truck,and i noticed after i got everything together that right where the front driveshaft meets the transfercase its got a pretty bad leak,almost like a gear oil,it reeks bad.
is this a hard seal to replace? is it expensive? and uhm,whats it called,so i can do a part lookup? if it aint one things its another! gah!
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
![]() Join Date: Jan 2007
Re: front of transfercase leaking after frontend replacement
I changed the front seal and gasket of the NP205 while it was still in my truck. I had to remove the front axle/u-joint and then tackle the output shaft nut...with a impact air wrench. The nut needed to be removed so that the output housing cover could be removed. But it was all done while the t.c. was in the truck.
I guess it depends on what your t.c. is, also.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
>>> right where the front driveshaft meets the transfercase its got a pretty bad leak,almost like a gear oil,it reeks bad.<<< >>>and uhm,whats it called,so i can do a part lookup?<<<
Humm, Output shaft seal and if it smells like gear oil you may want to drain it and fill with 10-40w motor oil.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
