Old 11-28-2010, 04:36 AM   #1
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Fuel Tank Strap Replacement on Fleetsides
I removed my tank for flushing and both straps broke, so I need to replace them. LMC and Classic Industries along with a few others sell the straps by themselves. The original straps are riveted to the brackets, which I do not need to replace.
I'm assuming I have to grind out the 3 rivets on each bracket to install the new ones with bolts??? Has anyone ever done this?
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-28-2010, 06:31 AM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: Fuel Tank Strap Replacement on Fleetsides
i was lucky enough that when i pulled my tank the straps were in good shape. but in this situiation it would be best to weld the new straps on the bracket as bolts have the chance of becoming loose over time, another option would be to put in new rivits.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 11-28-2010, 07:36 AM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Bolt heads may wear holes in the bottom of the tank. Like bucannon said, be best to weld them on IMO.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-28-2010, 04:23 PM   #4
Acrophobia
Acrophobia's Avatar
I replaced mine with bolts. The head of the bolts dont stick up past the ridge on the bracket. I did put a small piece of rubber above the head of the bolts to give it some cushion just in case though.
Acrophobia is offline   Reply With Quote
Old 11-28-2010, 09:35 PM   #5
TheWhiteElephant
God is good!
Yes, that's what I'm going to do. I appreciate the input, folks.
Mando
